Remove paint from headlights
Old Mar 5, 2012 | 02:49 PM
AtomicX's Avatar
AtomicX
Default Remove paint from headlights
Hey guys so I bought my 350z and the previous owner took clearcoat with some black paint and painted the headlights. Well now no inspection shop will pass me. Anyone know how to get the black off without ruining the headlights?
Heres a picture
Old Mar 5, 2012 | 03:00 PM
Italianjoe1's Avatar
Italianjoe1
Paint thinner or acetone should take it off. They might have sanded the headlights down first, which means they will look like crap until you clear them again. Try the method posted here recently for headlight uv coating restoration, gave a nice idea for putting some clear back on without any actual paintwork.
Old Mar 5, 2012 | 04:03 PM
ZSilverBullet28's Avatar
ZSilverBullet28
People like the painted lights. You could just but a new set and sell your set. You might make some money too.. Might be a little too much work though. Up to you.
Old Mar 5, 2012 | 04:34 PM
kevincat's Avatar
kevincat
i wouldnt recommend using acetone/paint thinner on clear plastic. you will actually end up burning the lens.
just use sandpapers to remove the paint. 600>1000>1500>2000>3000grits
hopefully that helps
Old Mar 5, 2012 | 04:57 PM
Is the paint on the inside or outside?
Old Mar 5, 2012 | 05:48 PM
bbs350z's Avatar
bbs350z
try something along the lines of spray paint remover, or something that takes sprayed paint off. if it was professionally painted, then your best bet is acetone. do not use anything harsher like aircraft remover or your lights will look like swiss cheese
Old Mar 5, 2012 | 09:01 PM
bmccann101's Avatar
bmccann101
youre never going to get a good finish once the lights have had the UV hardcoat sanded off.
Buy a set of 03-05 DEPO brand complete halogen headlights from ebay, 175 bucks shipped, warm your oven to 250 degrees adn put themn in there for 1o minutes.. take teh lenses off them and replace the current w brand new clear ones.. far far easier a job too i can assure you. ONLY sounds scary.
Old Mar 5, 2012 | 10:39 PM
Waiz's Avatar
Waiz
OP, you're going to need to do something about those wheels too. It doesn't look like they were made for a RWD car given their sunkeness
Old Mar 6, 2012 | 05:12 AM
BoomerZ33's Avatar
BoomerZ33
yup sandpaper should work. or sell them and upgrade to 06-08 bixenons.
Old Mar 6, 2012 | 08:05 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I say find a local through CL or something and trade them out, shouldn't be that hard
Old Mar 6, 2012 | 01:16 PM
BRIANZ1's Avatar
BRIANZ1
sandpaper but i like the look dont you
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
Cashwin
Oct 1, 2015 06:36 AM
JGee450
Sep 30, 2015 04:32 AM
