350z headlight upgrades
Old May 27, 2012 | 03:48 PM
350zUSNavy's Avatar
350zUSNavy
Default 350z headlight upgrades
Does anyone know where i can get the Iron man headlights for my 06 z
Old May 27, 2012 | 04:08 PM
silverbullet_Z's Avatar
silverbullet_Z
You have to be Tony Stark in order to afford them I would also like to know.
Old May 27, 2012 | 04:47 PM
Delta_two-Niner's Avatar
Delta_two-Niner
Subscribe to Zleds on facebook....they Specialize in this work...Including but not limited to 350z modifications, reflector upgrades, and much more.
I hope they're ok with posting this info... if interested their email is:
zleds.sales@gmail.com
Hope this helps!!
Old May 27, 2012 | 05:10 PM
Guilty1s's Avatar
Guilty1s
you get a pair of these: http://www.theretrofitsource.com/pro...roducts_id=103
Put the CCFLs around your projector behind the shroud. Then you just sand the thin layer of paint of the 4 concers of the projector shroud.
Use some gluedots to mount the invertor inside, wire into parking lights. Reseal, done.
They have since come out with LED rings that dont need invertors now which would make it easier, but i cant contest to thier quality. The retrofitsources ones were ok Quality. They are good, just fragile.Really not much way around it.
Old May 27, 2012 | 05:25 PM
R350Zz33's Avatar
R350Zz33
s&A did mine
sacustoms12@yahoo.com
they have cheaper priceing then the other vendors on here and they are a vendor tell sam rich sent u
Old May 27, 2012 | 05:43 PM
SirSpeedyZ's Avatar
SirSpeedyZ
There are several DIYs here for that mod
Old May 27, 2012 | 09:17 PM
User 42426's Avatar
User 42426
If you do it yourself you it will cost less than 100 bucks for everything, prob around 70-80
Old May 27, 2012 | 09:46 PM
Delta_two-Niner
yeah if you DIY....it can be done for cheap..but remember that with amateur work you get amateur results.....i did an fx-r retro in my 350z and had to have a custom shroud made by a local company...that company COMPLETELY flubbed it up so now im stuck with a retro i wanted to turn out a little differently.
Old May 27, 2012 | 10:10 PM
Waiz's Avatar
Waiz
Originally Posted by R350Zz33
s&A did mine
We also have two DIY's to reference
https://my350z.com/forum/body-interi...eadlights.html
https://my350z.com/forum/body-interi...hting-diy-460/
bcoffee20
Nov 19, 2015 06:39 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
foxsmp26
Sep 25, 2015 09:48 AM
B Esquire
Sep 24, 2015 07:52 AM
hardkicks
Sep 20, 2015 12:28 PM
