Solutions for Covering Aftermarket Sunroof...
Old Jul 14, 2012 | 02:28 PM
cookiemonsterJS's Avatar
cookiemonsterJS
Default Solutions for Covering Aftermarket Sunroof...
Hi guys, I'm a new Z owner as of today, just picked up an 07 Silver Grand Touring MT6 w/ 35k on the clock that's been awesome to me....except for one thing. The previous owner installed a cheap sunroof on the Z! (http://www.sunroofdoctor.com/sfcsunroof.htm) and at highway speeds (70-85+) the wind noise is pretty bad.
I'm thinking of 2 things - either trying to make a better seal or covering it. My question to those of you with the knowledge/experience is, how would I go about EFFECTIVELY covering it to make sure there would be no wind noise from the cover and more importantly, that it would truly seal and not look hideous like someone just riveted some crap down. Also, if you have ballpark figures for cost, I know nothing's going to be exact, I'm just trying to figure out which avenue to take.
I can say that I don't mind having it THAT much, but there's not internal cover, so the sun shines right through the tint all day, and it only protects against 92% of UV Rays which isn't good enough for a pale guy like me who lives in FL.
Your thoughts/advice would be greatly appreciated!
Old Jul 14, 2012 | 03:30 PM
JCITY's Avatar
JCITY
That is one cheap azz sunroof.Its really a pop roof.
What other "great" mods did the previous owner do to your Z?
Depending on your budget,getting the thing removed and filled in correctly
will be costly.You must have got a great deal to buy a Z with this type of crap roof.
An option would be a roof overlay...CF(carbon fiber).You could probably get the hole sealed,new headliner,make sure the roof has a smooth surface,slap on the roof overlay.
I've not seen this done OVER a sunroof hole,but it seems possible.
Actually,never met anyone dumb enough to cut the roof of a Z and install this ricer part.
Good luck.
I'll bet you will get some "creative" posts to your problem.
Old Jul 15, 2012 | 08:21 AM
bmccann101's Avatar
bmccann101
Good luck.
buy a new headliner that is uncut used from slidegood.com.. have some sheet metal lightly tacked in ..prime for rust..seal with silicone.
cover it all up w a carbon fiber roof cover.
Done cheaply.
Old Jul 15, 2012 | 09:12 AM
QuintonC's Avatar
QuintonC
^ That's what I was thinking. You could also try to find an Asuka Double Hump roof and cover it up after you get a new headliner and have a guy tack in some sheet metal
Old Jul 16, 2012 | 05:21 AM
cookiemonsterJS
Done cheaply.
I did some research and I think Seibon is the only CF roof i'd go with, and it's 960 bucks...so that probably wouldn't happen.
Is there any reason why I can't just go with part # 112-CF4MA (Roof) and get a body shop to swap them out? The rails and all of that extra stuff has to still be there, so it should just be the actual roof...I figure that part (about 400) plus paint and labor should be about 600 bucks total, MAYBE 700, right?
What do you guys think? Am I missing anything? I just think welding **** and still paying over 400 bucks would just suck. I'd rather pay 6-700 and have it be OEM, the way it's supposed to be, no worries about rust or seals or any of that crap.
Old Jul 16, 2012 | 05:32 AM
cookiemonsterJS
Good luck.
Ironically, that's the only mod they did to this Z, EVERYTHING else is stock. I did get a really good deal. I got a GT '07 with 35k miles on a 1 owner car for 20k from a dealer, that should have easily been 23000. I wanted to go private party, but had to finance, so dealer was my only option, and ALL other dealers within 1k miles were charging 20k (before taxes) for BASE models with 60-70k miles in much worse condition.
Realistically, the only issue with this car IS the sunroof, while a big issue, it's not a deal breaker for me, I just need to figure out if I can afford to fix it the right way (sheet metal + CF overlay + Paint?) or if I need to just make a better seal and live with it how it is for now.
Old Jul 16, 2012 | 10:33 AM
TPete19's Avatar
TPete19
I would think that the only way to replace the roof panel would be to weld it in... No?
I'd have a body shop weld in a new piece or another roof cut from a parts car. Get a new/used headliner and you're golden.
It'll end up being less expensive than doing the CF panel cover-up idea and will actually be done right, not just hiding the problem.
Old Jul 16, 2012 | 11:44 AM
bmccann101's Avatar
bmccann101
true. ^
Old Jul 16, 2012 | 02:35 PM
Waiz's Avatar
Waiz
If the sunroof was installed correctly and you can have a shop confirm that the structural integrity of the roof has been maintained and I would actually try to fix the sunroof so that you can continue to use it.
A sunroof on a Z is a pretty rare sight and if you can get it fixed so that it it works properly your Z will be worth more to an enthusiast in the future.
It might negatively affect your resale value to a dealer but privately you could raise the value if you save the receipts from the repair.
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
