power/heater seat with OEM heater buttons center console PLEASE HELP!!!
Old Oct 20, 2012 | 01:19 AM
birdman542905's Avatar
birdman542905
Default power/heater seat with OEM heater buttons center console PLEASE HELP!!!
I got power/heater seat in my 03 base model. I took the time to buy the OEM center cosole with the OEM butons for the heaters. I plugged all the wires how they go. They still dont move or heat :\. Is something missing? connected yellow, white, and white small how they go and I cant even move the seat or heat. Winter is coming I really need them. Help is highly appreciated. Thank you
Old Oct 20, 2012 | 07:12 AM
Tackett's Avatar
Tackett
Check the fuse boss.
My bet is since it didn't come with it from the factory, there is no fuse in the appropriate slot.
Find it and install one. I can't recall the amperage. It should say on the diagram in the manual.
Old Oct 20, 2012 | 07:39 AM
terrasmak's Avatar
Relay, its in back under the 12v power receptical barely accesable from the glove box.
Old Oct 20, 2012 | 10:53 AM
Tackett's Avatar
Tackett
Ahh.
There u go.
Old Oct 21, 2012 | 04:15 PM
birdman542905
installed relay today. I had to take the car apart from behind the passenger seat to install it. Still no power.... maybe a fuse missing?
Old Oct 21, 2012 | 04:39 PM
bonaldgonza's Avatar
bonaldgonza
Old Oct 21, 2012 | 05:07 PM
labelworkshop75's Avatar
labelworkshop75
I believe you can't plug and play install this into a base model's wire harness. You must hard wire. There are a few threads on this.
Old Oct 22, 2012 | 12:02 AM
birdman542905
oh ok thanks. i did my research and i heard you have to buy a pin to wire the power to the seats. So i guess im going to have to call tomorrow to get some information about that. the comes from the power to windows and power to seats. That would probably be my next move. Ill keep you informed
350z82
Oct 1, 2015 06:25 PM
