Wipers hitting below window. click click click shoot me
Old Nov 17, 2012 | 08:35 PM
bmcmvox's Avatar
bmcmvox
Default Wipers hitting below window. click click click shoot me
Look at me, I don't fully inspect everything before buying a car. So my wipers are making a clicking sound because they are hitting the trim below the window. When they are off, they are sitting about an inch below the window. I can manually move them up and down an inch and a half when the are in off position. This leads me to believe that either something is loose, or broke. Could be that little gear in their that sets them in place...possibly stripped? I have read that some cars you can tighten the bolt itself under the dressing cap to actually hold the blades in place with friction, can you do that on the 350z? any thoughts?
thanks in advance
Old Nov 17, 2012 | 09:46 PM
R350Zz33's Avatar
R350Zz33
thanks in advance
undo the nuts that hold the wiper nuts on move them up one spline test and redo untill its right simple
Old Nov 17, 2012 | 10:05 PM
aboveliquidice's Avatar
aboveliquidice
^This...dead simple fix
Old Nov 18, 2012 | 01:44 AM
bmcmvox's Avatar
bmcmvox
Cool, I will give it a try in the morning. Thanks
Old Nov 18, 2012 | 07:22 PM
bmcmvox's Avatar
bmcmvox
Ok didn't have time to examine issue today. But I did notice something else, when they come up, the driver side is slightly over shooting the window. So it is going down too low, and coming up too high. I am thinking not an alignment issue. They also stay on when the car is off. have to manually turn them off. Looked online, cant see anything about this being a feature of the 350z.
yeah. Awesome.
Old Nov 18, 2012 | 08:04 PM
Russ@Z1's Avatar
Russ@Z1
Are the wiper arms on the correct sides of the car?
Old Nov 18, 2012 | 08:44 PM
bmcmvox's Avatar
bmcmvox
Just measured. Driver:20 Passenger:18. Like I said in the first post, when they are in park position, I can physical move them up and down a couple inches. On my Altima, I can`t. When they are off, the arms don`t move.
Old Nov 19, 2012 | 09:12 AM
TPete19's Avatar
TPete19
yeah. Awesome.
They stay on when the car is off? I'm thinking someone did some work to the wiper motors and didn't reinstall correctly as they're getting constant power rather than switched.
I'm not sure whether the wiper motor can have the extra travel like you're describing or if someone installed the wrong one.
I can't really blame you though for not checking the wipers function... I've never tested them on any car that I've purchased either.
Old Nov 19, 2012 | 08:23 PM
bmcmvox's Avatar
bmcmvox
Man, it is getting to the point I suppose I just need to take it to the mechanic and bite the bullet. Wiring issue, possible wrong motor....man.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
bneumann
Oct 7, 2015 12:16 PM
