08-09: Switchback dual front turn signals?
Well, I was looking in to Z-Led's for the front reflectors and rear turn signals and they offer switchback versions. I'm not sure if I want to run wire and tap in to the oem harness though. If you have some could you post your install experience?
Back to the subject: The front has two amber turn signal bulbs per side. They are not on with the headlights, only for turns. There is a tiny little bulb and an amber LED strip that turns on with the head lights. So my question is will a switchback LED bulb work for the turn signal bulbs or does it have to be wired for that already?
https://my350z.com/forum/body-exteri...some-look.html
Didn't answer my question. The thread above says some models may need to be rewired?
So in this Z-Led video, it looks like the dual signal bulbs were removed and used for the headlight LED strip and the LED switchback reflector replacement. I don't like having the holes where the bulbs used to be though. http://sm-a1.yimg.com/image/?url=htt...j1IOvzrCCg--~B
If I can do switchback LED bulbs then I may not dish out the do ray me for the LED.
