2008 350z door sills and hood latch area - Is this normal?
Old Feb 1, 2013 | 09:45 PM
Castor771's Avatar
Castor771
Default 2008 350z door sills and hood latch area - Is this normal?
This is my first post. Hello all. I have been following this thread since June 2012 when we took ownership of a 2008 350Z Grand Touring. Very sweet car indeed. I never owned a true, two door sports car with only two seats.
Now, I am calling out to all Nissan techs and experienced 350Z owners....
Pardon for the dirt. Haven't had time to wash the car.
Question #1:
The door sills aren't completely lined up. Is this normal for all 350Zs?
Question #2:
Someone also mentioned to me that there is overspray under the hood latch area indicating the possibility of body work performed. Is this overspray or is this normal for all 350Zs?
The car was purchased as a certified pre-owned so I doubt it was involved in a collision as the carfax came back clean unless the prior owner got it fixed without reporting it. I also ran an autocheck by experian and it's clean.
Any input is greatly appreciated.
Thanks all,
Andrew
Attached Thumbnails 2008 350z door sills and hood latch area - Is this normal?-driver-side-door-sill.jpg   2008 350z door sills and hood latch area - Is this normal?-passenger-side-door-sill.jpg   2008 350z door sills and hood latch area - Is this normal?-driver-side-hood-latch-area.jpg   2008 350z door sills and hood latch area - Is this normal?-passenger-side-hood-latch-area.jpg
Old Feb 2, 2013 | 07:35 PM
Castor771's Avatar
Castor771
I guess this normal as there has been over 100 views and no replies.
Old Feb 2, 2013 | 08:18 PM
dkmura's Avatar
dkmura
General & DIY Moderator
If you're referring to the rocker panel fit, there are small white plastic clips that hold them to the side of the Z. If any of them get damaged or broken, the gaps between them and the bottom of the door can get slightly bigger.
As for the hood latch area, it's hard to tell much from your pics. Some overspray or paint drips on the backside of the hood are within normal production limits.
Old Feb 2, 2013 | 09:02 PM
Castor771's Avatar
Castor771
Thanks dkmura. Will check for the white plastic clips.
As for the hood latch area, I thought it was normal but was given mis-information from some haters that apparently don't own a Z and wanted one.
Thanks for the clarification.
Old Feb 3, 2013 | 06:12 AM
Airkilo's Avatar
Airkilo
I just looked at mine and there is gap for my door seals. I think its typical.
Old Feb 3, 2013 | 09:22 AM
Castor771's Avatar
Castor771
Thanks for checking Airkilo.
m_0g
Jun 3, 2021 10:05 AM
hardkicks
Sep 20, 2015 12:28 PM
350z_z33.
Sep 9, 2015 09:50 PM
Darkspy
Sep 7, 2015 09:09 PM
