350z interior door handle scratches
I have a 2008 350z when i bought it.It came with some interior door handle scratches. is there a good fix for this problem i understand that it is not a uncommon problem with the 350z.
Duplicolor. Check this post for the specific paint to buy:
https://my350z.com/forum/9174801-post310.html
Definitely don't sand, primer and paint.
Did mine the other day , scrape as much as you can off with whatever you wanna use, I used a CD lol (bored at work) then take remaining material off with wax and grease remover so it's bare down to the shiny gray layer . scuff it with a scuff pad and use vinyl paint, it's tehnically not spray paint. I got mine at NAPA its about $10 , company called SEM makes it, you may have to ask for it. Takes no more than a half hour per piece
Ehh.... whatever floats your boat I guess. But that takes forever and costs more , sanding that rubbery stuff is a pain in the *** and trying to get in the button crevices is even worse. Just my opinion of course.
I found Color Bond LVP refinisher for leather vinyl and plastic to be a real good match for my 350Z interior. The color I chose is #244 Honda Black. When I looked at my Honda interior it looked like the same color to me. I've got 8 cans of paint here and tested all and held them against my lid cover (various Black and Graphite colors). After spraying the lid I can't see a difference at all in color even the sheen matches. You can find the paint on Amazon/eBay/Summit it's a little on the pricey side but hides in two coats and is a perfect match. I didn't even have to paint the whole lid I just sprayed some in a cup and brushed it on and I can't tell in bright sun that it's been touched.
Last edited by Jeff Swallow; Jul 24, 2018 at 02:41 AM. Reason: I added Summit becasue I found it on the shelf yesterday.
I found Color Bond LVP refinisher for leather vinyl and plastic to be a real good match for my 350Z interior. The color I chose is #244 Honda Black. When I looked at my Honda interior it looked like the same color to me. I've got 8 cans of paint here and tested all and held them against my lid cover (various Black and Graphite colors). After spraying the lid I can't see a difference at all in color even the sheen matches. You can find the paint on Amazon/eBay it's a little on the pricey side but hides in two coats and is a great match.
bcoffee20
Nov 19, 2015 06:39 PM
hardkicks
Sep 20, 2015 12:28 PM
good luck
