06+ headlight connector question
Old Aug 9, 2013 | 12:00 AM
Touge Z's Avatar
Touge Z
Default 06+ headlight connector question
so I got some 08 headlights for my 03 track edition. the headlights are used and came with the guts, bulbs, ballast and everything. from reading online, the 08 connector should be an 8 pin. the one on mine has 8 slots but 7 prongs sticking out. is it suppose to be like that?
Old Aug 9, 2013 | 05:21 AM
Touge Z's Avatar
Touge Z
after more research, someone said it's a 7 pin connector because one pin doesn't do anything. can anyone confirm?
Old Aug 9, 2013 | 06:41 AM
Calinismo350z's Avatar
Calinismo350z
yes I believe it's the one with the blue cable. blue and green are the same. cut the connector from your 03 leave enought wire space, then cut the connector from your 06-08 leave the same space. them your going to add all the cables se color. just the blue one add to the green. At the end your gonna have blue and green wire going in to your 03 plug. hope I was clear enough. good luck
Old Aug 9, 2013 | 07:04 AM
Touge Z's Avatar
Touge Z
I thought it's plug and play, no wire cutting since I have stock hids in my 03. the 08 headlights came with everything too.
Old Aug 9, 2013 | 07:27 AM
Calinismo350z
no its not because 03-05 plug is different from 06-08.
Old Aug 9, 2013 | 09:23 AM
BY350z's Avatar
BY350z
Huh? Don't listen to that guy he doesn't have f@cking clue on what he is talking about, there's no need to cut anything, everything is plug n play is u have oem hid. Follow this guide and you're all set
https://my350z.com/forum/body-interi...lkthrough.html
Old Aug 9, 2013 | 11:44 AM
Touge Z's Avatar
Touge Z
has anyone plugged 06+ headlights into pre 06 350z with stock hids, without modifying anything?
Old Aug 9, 2013 | 11:52 AM
Calinismo350z
yeah sure that's why my 07+ headlights are working perfectly on my 04. haha
Touge Z, my bad just double checked your post. mine was a base model so that explains the cutting but if you have oem HID it should just be plug and play since you say the 08 come with bulbs and everything.
Old Aug 9, 2013 | 12:22 PM
Touge Z's Avatar
Touge Z
I would install it already but I'm just waiting on my clear reflectors to get here so I can install them while the bumper is off.
Old Aug 9, 2013 | 06:39 PM
Emagana's Avatar
Emagana
Does anyone know anyone selling a pair of 06 headlights? Or if they sell just the housing for em?
Old Aug 13, 2013 | 10:41 AM
mcubed45's Avatar
mcubed45
https://my350z.com/forum/exterior-an...eadlights.html
Apparently depo just started selling these 06-08 oem style for pretty cheap. There's a couple people ordering some in that thread. Waiting to hear back once they get them. It's sold as just the housing (no bulbs/ballasts).
Old Aug 13, 2013 | 11:01 AM
Touge Z's Avatar
Touge Z
so I installed my 08 headlights yesterday, direct plug and play with 08 wiring harness.
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
