Depo 06+ style headlights and other aftermarket headlights thread
Old Dec 18, 2013 | 08:58 PM
  #421
NOLAGG's Avatar
NOLAGG
Anyone getting condensation in their lights? It's about 29 degrees here in nyc with periodic snow and my lights are 2 days old with moisture in them already ?
Old Dec 18, 2013 | 09:15 PM
  #422
BranZ's Avatar
BranZ
Not me, been on a couple months.
Old Dec 19, 2013 | 05:16 AM
  #423
NOLAGG's Avatar
NOLAGG
Ahhhhhh so now I have to open them or let them dry and try silicone I guess . Besides the headlight bulbs and blinker bulbs what is that other bulb that goes in the headlight ? Looks like an led slot
Old Dec 19, 2013 | 06:11 AM
  #424
XG624's Avatar
XG624
Haven't had an issue and also local. Did you carry over both ballast gaskets and the gaskets for the white twist covering?
I was just about done when I realized I left a gasket off one of the ballasts so I had to go back, remove, and re install with the second ballast gasket to avoid future condensation.
Old Dec 19, 2013 | 08:57 AM
  #425
HotZauce's Avatar
HotZauce
Mine had condensation in them for about the first week or two. It cleared up on its own.
Old Dec 19, 2013 | 09:49 AM
  #426
NOLAGG's Avatar
NOLAGG
What do you mean ? Your using 2 ballast gaskets ? Like the rubber oring? I only had the 1 for each tha were off my 03 ballasts
Old Dec 19, 2013 | 10:44 AM
  #427
XG624's Avatar
XG624
Each headlight had 1 gasket per ballast and 1 per white cap on the back. I was just saying I forgot to put 1 of the ballast gaskets back on the new lights but went back to avoid condensation, just throwing it out there in case you might have forgotten it too. I didn't see it the first time around, was stuck to my old headlight and found it on the second one.
Old Dec 19, 2013 | 11:34 AM
  #428
NOLAGG's Avatar
NOLAGG
Oh yeah their both on there , thanks for the look out though .
Old Dec 20, 2013 | 02:08 AM
  #429
NOLAGG's Avatar
NOLAGG
My last and final question in regards to these depot headlights I'm starting to regret getting .
What would cause my turn signals not to work on these? I put my signal on and it blinks fast in the cabin as if the bulbs are out or burnt out ? All bulbs are in and working btw .
Cutting the blue wire makes the blinkers work ? Or
Old Dec 20, 2013 | 08:04 AM
  #430
BranZ's Avatar
BranZ
When that happens it's because a bulb is going out, or is out. It could be your rear turn signal bulbs too. I'd check all 4 turn signal bulbs. Blinking fast inside the car has nothing to do with the headlights. Unless you wired something wrong.
Old Dec 20, 2013 | 04:16 PM
  #431
NOLAGG's Avatar
NOLAGG
Both bulbs are on and the right blinker blinks at normal pace. The left one blinks fast and doesn't blink up front ? Brand new bulbs and both work when on , just the driver doesn't blink ??
Old Dec 20, 2013 | 07:37 PM
  #432
MyO3Z's Avatar
MyO3Z
What is everyone using to re-seal their lights? Going to take on this project this weekend.
And to answer the question D2R and D2S. Just spend the $50 to get the D2S bulbs.
D2R (R - being for reflective) are why the 03-05 headlights have a projector lens WITH a reflector on the sides.
The D2S bulb is meant for full light output through the projector lens.
Old Dec 20, 2013 | 07:47 PM
  #433
G4nismo's Avatar
G4nismo
if i could do this over, i'd prod use the nissan butyl tape sealer for a cleaner seal. not sure how it'll hold up though.
Old Dec 20, 2013 | 07:51 PM
  #434
MyO3Z's Avatar
MyO3Z
Just ordered mine as well finally lol . And can you elaborate on it seeming like it won't line up as I def want to do the ironman mod and just wanted to see how your going about this . How much is the mod going to cost you and where did you get your stuff to do it from as there are a couple of vendors and I'm unsure of which one to go with . Thanks in advance
The seal was just so tight on them from never being opened that I had to pry the covers open. I just felt like I was breaking them at first. lol
---Parts list---
STi lenses and D2S bulbs are from The Retrofit Source
Got some red LED's for the Demon eye mod off Ebay (make sure to get ones that have a resister inline, otherwise they will just burn out with 12v)
And the halos for the Iron Man mod were from retro-solutions.net. I got them in the 95mm size.
Old Dec 20, 2013 | 09:24 PM
  #435
NOLAGG's Avatar
NOLAGG
If I'm having oxidation on the lower part of my lights (inside the light has moisture when it rains )can I just seal over the current seal to stop this ? Silicone anything specific ?
Old Dec 21, 2013 | 06:25 PM
  #436
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
I would use a headlight restoration kit to remove the oxidation before sealing. Most kits should come with a sealant as well so anything that gets removed in the cleaning process can be resealed.
Old Dec 21, 2013 | 06:39 PM
  #437
quakerroatmeal's Avatar
quakerroatmeal
Eric did you change over yet?
Old Dec 21, 2013 | 07:15 PM
  #438
sportyaccordy's Avatar
sportyaccordy
D2S is actually pretty good on the 03-05 OEM headlights too. Noticeably brighter without much added glare.
But yea for this it's absolutely worth it. Even more worth it to get some name brand bulbs like the Philips 85122+s
Old Dec 21, 2013 | 10:53 PM
  #439
MyO3Z's Avatar
MyO3Z
Ok, so haven't done much searching, but how did people go about with the IronMan mod? Mine didn't have any clear spots on the shrouds, other than the lines down the sides....I sanded off some paint, but it didn't look right, so ended up painting over the shroud and saying hell with the mod. Plus I accidentally broke a CCFL Halo and didn't feel like waiting a week to get this project finished lol
So I guess I'm just wondering if some have the clear spots, or if they have to be "made"
Old Dec 22, 2013 | 12:36 PM
  #440
NOLAGG's Avatar
NOLAGG
Ahhh I can't believe I'm the only one who's getting condensation on both lower portions of my headlights smh. I can't figure out where it's coming from
