Depo 06+ style headlights and other aftermarket headlights thread
Old Jan 31, 2014 | 05:34 AM
  #481
Z_on_TE37's's Avatar
Z_on_TE37's
Originally Posted by t0psecretx7
I have an 03 touring. all you'll need is a set of D2S bulbs and the only wire you'll need to snip is the blue wire on the depot headlight that runs to the turning signals. (or else they'll stay on all the time as DRLs)
Thank you very much! I get them tomorrow so I may throw them in tomorrow. Anyone run generic d2s bulbs ? I don't feel like spending 150 on Phillips bulbs
Old Feb 1, 2014 | 07:43 AM
  #482
Z_on_TE37's
Well, got my lights today, and the passenger side is missing that black cover over the led strip up top. Hopefully this doesn't end up as a major deal breaker.
Old Feb 3, 2014 | 01:27 PM
  #483
t0psecretx7's Avatar
t0psecretx7
Originally Posted by peacker
The socket withe the new silicone added
I only get condensation when it's cold and my lights are on, the condensation builds up where the beam hits the lens. Is that the same issue you had?
Old Feb 23, 2014 | 10:42 PM
  #484
Venom36's Avatar
Venom36
Angry
I have been looking for these lights does anyone know where i can purchase them i cant find on ebay
Old Feb 24, 2014 | 05:39 AM
  #485
Z_on_TE37's
Just type 350z depo light and you'll find them on eBay
Edit: I just looked last night and they were there, none are listed right now.
Old Feb 24, 2014 | 10:43 AM
  #486
Venom36's Avatar
Venom36
No luck yet anyone know where you can purchase these besides ebay?
Old Feb 24, 2014 | 10:46 AM
  #487
travlee's Avatar
travlee
Master
if you can live without headlights for a bit....
http://www.twistedhouzings.com/
Old Mar 1, 2014 | 10:02 AM
  #488
onetimebob's Avatar
onetimebob
Exclamation problem?
i was taking apart my depo's in prep for a few mods and noticed this possible monstrosity of a problem in the chrome of the reflector bowls. the left isn't nearly as bad as the right, but will this be a problem or does anyone know of a quick fix for this?
Depo 06+ style headlights and other aftermarket headlights thread-yj5bbrh.jpg
Depo 06+ style headlights and other aftermarket headlights thread-7ijequr.jpg
Depo 06+ style headlights and other aftermarket headlights thread-ffh1mcg.jpg
Old Mar 4, 2014 | 06:57 AM
  #489
tjc6591's Avatar
tjc6591
Default Q's about installing Depo headlights on a 07 !!
Ordered me a set of the blacked out depo's today and seen it saying it doesn't come with the bulbs or ballast. I have the stock headlights and setup on my 07.
Question is, is all I need to hook up the depo's already in my stock headlights ?
Will the ballast and all the bulbs fit into the depo's, or am I gonna have to order new bulbs and ballast ?
Also considering going with a brighter bulb, any output on that ?
Old Mar 4, 2014 | 07:05 AM
  #490
travlee's Avatar
travlee
Master
if it were me.... here is what i would do in your instance... put on the depos, and then find someone to crack open and paint your oem's. you will have a better output with them. after you get your painted oem's back, offload the depo ones, they will sell fast
Old Mar 4, 2014 | 08:38 AM
  #491
DrummerGirl's Avatar
DrummerGirl
Yes. You just gotta pull out the ballast and bulbs out of your OEM's and they'll plug right into the depos. You don't have to worry about annoying wiring or anything like that. It should be pretty simple and straight forward.
Old Mar 4, 2014 | 02:16 PM
  #492
tjc6591's Avatar
tjc6591
Thanks for the reply, another question, sorry I'm such a newb about headlights, I just don't wanna mess anything up.
Do you think it'd do good to get new hid bulbs that's alil brighter ?
I guess it's all up to me but is there a certain size bulb that specifically fits into the housing ?
Old Mar 4, 2014 | 03:01 PM
  #493
DrummerGirl
Honestly I didn't notice a difference in brightness between OEM to DEPO, and I had the STI-r lenses on my OEM ones and not on my depo ones. Not saying the output was the same but it wasn't a drastic enough difference for me to notice so, take that how you will.
Personally I'm not a pro on headlights either, however if I remember correctly the bulbs for HID's are D2S.
Old Mar 12, 2014 | 03:36 PM
  #494
350zEric's Avatar
350zEric
Very interested in doing the setup.
Got a question on it though as i couldn't find any reference from previous threads. When i bought my 03-05 base the owner retrofit'd some ddm tunning HID on the stock non-hid headlights. How much modification will i need to do if i use my existing HID kit on the car? can i reuse the same harness?
I checked around other 350z reference forums some members state i can use the 03-05 harness with my after market hid kit, but i would like to hear those who use the aftermarket hid kits on these.
Thanks in advance for any inputs!
Old Mar 13, 2014 | 08:35 AM
  #495
mcubed45's Avatar
mcubed45
You can't reuse anything from an aftermarket HID retrofit kit. The ballasts, bulbs, and igniters are all not compatible with the stock HID system.
You can buy oem compatible bulbs/ballasts/igniters from www.theretrofitsource.com for a reasonable price (along with STi lenses if you plan on upgrading).
Old Mar 13, 2014 | 10:55 AM
  #496
G4nismo's Avatar
G4nismo
well one of my headlights started getting condensation. i shoulda resealed better. sick of looking at it so i may just buy another set of DEPOs.
Old Mar 13, 2014 | 03:27 PM
  #497
350zEric's Avatar
350zEric
Thanks for the reply, but after reading the product description on these depo setup, aren't these just the housing? could i still use my aftermarket setup for these?
Old Mar 17, 2014 | 12:55 PM
  #498
FliPPER_Z's Avatar
FliPPER_Z
Yes, you can use your current HID ballast , simply drill some new holes and get a AMP to D2S adapter...however you will still need an OEM HID Ballast to cover the giant hole in the bottom and a new set of D2S Bulbs ..its kinda pointless to use an aftermarket HID setup at this point.
If I were you, just get the OEM Ballasts and D2S bulbs....
Old Mar 17, 2014 | 04:37 PM
  #499
350zEric's Avatar
350zEric
Thanks for the reply! this is what i need to know.
Old Mar 18, 2014 | 06:44 AM
  #500
mcubed45's Avatar
mcubed45
no. you can't. everything is different sizes.
