350z check engine bulb size.
Old Aug 17, 2013 | 01:14 PM
Perkyd's Avatar
Perkyd
Question 350z check engine bulb size.
My check engine bulb is burnt out. Can someone tell me the size of the bulb please. Much is appreciated.
Old Aug 17, 2013 | 02:12 PM
Jah70's Avatar
Jah70
Sounds like a new mod to me. Get some test pipes now lol. Try checking with the parts people at the Nissan dealerships. I tried searching but I could only find info on the outside lights and some of the interior lights. Nothing for the lights in the dashboard cluster.
Old Aug 17, 2013 | 03:48 PM
DavesZ#3's Avatar
DavesZ#3
I'm going to guess that's one soldered onto the circuit board of the gauge panel.
There are a couple of threads here on the forum by guys who have replaced all the bulbs in the dash with colored LEDs. Check through those and you might find some hints on what to use as a replacement.
Old Aug 17, 2013 | 06:54 PM
Perkyd's Avatar
Perkyd
Thank you guys for the input. Ill make a call to the dealership.
Old Aug 17, 2013 | 07:07 PM
l2iceman's Avatar
l2iceman
It's an led that's soldered on and not a simple twist bulb that's replaceable. I had that burn out on a previous car and had to get it soldered lol
Old Aug 18, 2013 | 12:44 PM
johnx818's Avatar
johnx818
How did you figure that??
Old Aug 18, 2013 | 01:26 PM
l2iceman's Avatar
l2iceman
When you insert the key and turn to access, e cluster lights up for a few seconds and the check engine light Is always one of the ones that light up. If you don't see this light up for a few seconds, then something is up lol
Old Aug 18, 2013 | 02:48 PM
KornerCarver's Avatar
KornerCarver
Did you buy the car recently? I bought a Miata about 5 years ago and when I went for the emission inspection, it was discovered the CEL had been removed along with the catalytic converter. Fortunately, the dealer had to fix everything so it was a minor inconvenience. It is possible a prior owner removed the CEL.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
_koubie_
Sep 20, 2015 06:34 PM
