Front Bumper Chin Guard Replacement
Old Jan 9, 2014 | 07:07 PM
akocur92's Avatar
akocur92
Default Front Bumper Chin Guard Replacement
I've been using this site for quite awhile now, and you guys helped out a lot. I decided to register and become a part of this wonder full website. Anyways back to my problem.
i scraped the bottom of the front bumper due to a low patch in the road that i didnt see. Now on my front bumper below the grill. There's that little black bumper guard broke its about an inch tall and thick and about 4feet long, does that come with the bumper or can I replace just that part, if so how and what is it called so it called so i can order it
Thanks.
Old Jan 9, 2014 | 08:22 PM
pyshin's Avatar
pyshin
Jesus.
If you're talking about the small "lip" that is a part of the bottom of your front bumper... it's not "an inch tall and thick and about 4feet long"... you literally just described a rectangular prism.
If that small "lip" is in fact what you are talking about... it is part of the front bumper and cannot be removed/replaced. Even at stock height I commonly scrape mine... and it's not like you can actually see it
Old Jan 9, 2014 | 08:24 PM
bealljk's Avatar
bealljk
I believe this is what you're after…
http://www.courtesyparts.com/62020w-...8-p-16891.html
Old Jan 9, 2014 | 08:28 PM
pyshin's Avatar
pyshin
^^^ That's just the lower grille insert. I hope that is what he's talking about because that's actually an easy fix.. But idk how that would be damaged by a simple low patch in the road without damaging the bumper itself.
Old Jan 9, 2014 | 09:04 PM
akocur92's Avatar
akocur92
Sorry if I'm no explaining it correct, it literally looks like this l_________l it's the _________ black guard underneath the bumper, I scraped it on the low patch and a part of it(not the bumper) snapped, the black piece underneath near the front, and its not the dirt pads either.
4 Feet was probably too long its probably maybe a foot?
It is also not an insert. Like I said it's underneath the bumper you can see it, if you are crouching or far away.
Old Jan 9, 2014 | 09:10 PM
akocur92's Avatar
akocur92
That might be it if that goes underneath the bumper, wish I could blow up the picture.
Old Jan 9, 2014 | 09:12 PM
pyshin's Avatar
pyshin
It's still not clear what you are talking about, honestly. You need to take a picture, circle what you're talking about, and post it.
And the part bealjk posted is not what you are looking for, it is a grille insert that is not underneath the bumper.
Old Jan 9, 2014 | 09:29 PM
dcains's Avatar
dcains
I think the OP is talking about the little vertical lip running across the bottom of the front bumper, back a bit from the front edge. My '08 has it, and it has been scraped, mostly from those concrete parking lot dividers when pulling into a space. I say if you can only see it "if you are crouching or far away", not to worry about it.
Old Jan 10, 2014 | 05:26 AM
akocur92's Avatar
akocur92
Yes that's exactly it
Should i not be worried, and just remove the rest of it?
Old Jan 10, 2014 | 05:57 AM
dcains's Avatar
dcains
Only some of the cars have that piece, and I think it was part of an aero option upgrade. may have just been on the GT's. I don't think it actually does much, though.
I'd probably just trim/pull the remaining piece off at this point. Looks like you may have also done some damage to the plastic undertray, which encloses the bottom of the engine compartment, too. Not worth buying the OEM piece, if that's the case, but this is a great upgrade:
http://www.zspeedperformance.com/ZSp...ld-zsp2001.htm
I think this may have been the first "mod" I did to my '08, and it's still one of my favorites. Looks great, it stiffens up the front end, and it makes oil changes much quicker. I actually bought the prototype, and then upgraded to the newest version, which has some nice detail improvements.
Old Jan 10, 2014 | 06:40 AM
timeltel's Avatar
timeltel
Regards, akocur92: That piece covers (and extends) the molded flange at the bottom of your OEM facia. It uses both existing bolts and supplied clips for installation. Referred to as an "air dam", an underbody aero option.
Pic can be found here (no association with vendor):
http://www.ebay.com/itm/Nissan-350Z-OEM-Front-Chin-Spoiler-Air-Deflector-/400621017247?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ANissan%7CModel%3A350Z&hash=item5d46df989f&vxp=mtr
You'll need to confirm this is the correct replacement.
Peace.
Old Jan 10, 2014 | 07:07 AM
dcains's Avatar
dcains
Thanks for the link - just bought one. I wasn't ever going to replace my scraped one, but for <$50 shipped, why not? Only 1 left.
Old Jan 10, 2014 | 07:51 AM
timeltel's Avatar
timeltel
Hi, dcains: Have one on my '08. Done it's duty, taken a beating. Nice finishing touch. I'm also running the ZSpeed under tray, pleased to get rid of the OEM tupperware version.
Another option for the underbody spoiler can be found here:
http://www.nissanpartswarehouse.com/...subcat3=134360
about half-way down the page.
Listed for "Track" model, different part #. Aware there's a difference but not sure what that may be. Sponsored by Peoria Nissan, vendor has been reliable, no-gouge pricing. Again, no association with seller. Glad the info was of use &
Peace.
Old Jan 10, 2014 | 12:02 PM
dcains's Avatar
dcains
Peace.
I can't guess what the difference might be, as all the bumpers look the same, at least in that area below the car. I'll wait and see what gets delivered, and post some pics.
Old Jan 10, 2014 | 05:39 PM
akocur92's Avatar
akocur92
Thank you Timeltel. i'll order one of those considering it looks weird without it. Even though you can barley see the part.
Dchains thanks for quick responce. I checked the engine splash guard. And thankfully that's not dmagaed. But I might consider replacing it as well.
Old Jan 14, 2014 | 07:41 AM
dcains's Avatar
dcains
Not much to it, but if you guys want to see the install instructions:
http://www.courtesyparts.com/images/...FCAFD_pg1.html
Old Jan 22, 2014 | 01:53 PM
dcains's Avatar
dcains
Got mine yesterday, only took a few minutes to install, and I was already down there for an oil/filter change.
Old Jan 25, 2014 | 12:38 PM
akocur92's Avatar
akocur92
Having trouble finding a place that his this neither of the links or where I look have it in stock. One of the links it said it would be about $30 dollars but the shipping was back order so it would of been like $80 with shipping
Any ideas where to order this?
Old Jan 25, 2014 | 01:00 PM
92K1500's Avatar
92K1500
I think that piece got ripped off my bumper a long time ago. My front bumper is a warzone and I'm not even lowered yet.
Old Jan 25, 2014 | 01:24 PM
dcains's Avatar
dcains
Courtesy Nissan has it.
1 x FRT CHIN D (K6010-CF40A) = $15.84 + shipping
You might also try a local dealer. Might cost more for the part, but you'd save the shipping.
issyz
Jul 2, 2017 03:04 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
sherm
Sep 10, 2015 11:02 PM
