Stock Side Skirts coming off
Old Feb 6, 2014 | 08:33 AM
MrRon's Avatar
MrRon
Default Stock Side Skirts coming off
The reason: The unavoidably high speed bumps where I live.
It doesn't look very bad from the side.
But once you get above it you can see it.
These little notches are showing, and there is about a half inch of space there.
And it looks like the "housing" of the notches are broken.
Would anyone know how to fix this?
And excuse the dirtiness of the passenger side...people don't know how keep their shoes clean -_-
Old Feb 6, 2014 | 04:52 PM
saywat?'s Avatar
saywat?
for starters I think the side skirt should tuck under the "side step"
Old Feb 6, 2014 | 04:58 PM
MrRon's Avatar
MrRon
We have a lead!
Old Feb 6, 2014 | 05:04 PM
KornerCarver's Avatar
KornerCarver
You might take it to a body shop. I suspect they would know how to fix your sideskirts.
Old Feb 6, 2014 | 05:37 PM
MrRon's Avatar
MrRon
I was also thinking that if no body knew how. lol
Old Feb 7, 2014 | 07:07 PM
savedbygrace's Avatar
savedbygrace
It's a guess, but I think you need new "housings", the female aspect of the clip.
I'd call the dealership and ask for the parts department and describe what you need. They can look up the part, and they can bring in their most relevant mechanic for this job and get that person's input on what parts you need.
Or call a Z-centric shop like Concept Z Performance or whatnot and I'm sure someone there would know.
Report back on how this goes if you would? I'm always up for learning and mayyyy have to do this myself as well, but not for a bit.
Saved
Old Feb 7, 2014 | 07:37 PM
terrasmak's Avatar
I do know the back corner is double sided taped on,
Old Feb 7, 2014 | 08:05 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Repeated blows to the side skirts have damaged both the female plugs and some of the male clips as well. Nissan does sell replacements, but you'll need to remove the phillips head screws in the fenderwells and 10 mm bolts underneath before you can get to them. There's also some double sided tape to replace towards the front of the side skirt.
Old Feb 8, 2014 | 10:47 AM
MrRon's Avatar
MrRon
So I just called Nissan, and they can order the Male/Female pieces, and they are about 1.50 each or something like that.
And for the front, I'll just go buy some 3M Double-Sided Tape.
Thanks for all the help guys!
Old Feb 8, 2014 | 11:47 AM
saywat?'s Avatar
saywat?
u gotta pop up the black side step thing then push the side skirt back into place. its not gonna lock in place with the side step in the way. if it doesn't lock in then go and replace those parts
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
hardkicks
Sep 20, 2015 12:28 PM
Suffolk350z
Sep 13, 2015 02:43 PM
