Airbag Light on Base 350z after Sparco Seat Install
Old May 11, 2014 | 10:21 AM
mwcarroll's Avatar
mwcarroll
Default Airbag Light on Base 350z after Sparco Seat Install
Prior to buying my Sparco Pro 2000s, I looked into what all was involved with removing the factory seats.
I have tried nearly every method of resetting the airbag light (including frying a resistor), but none have worked. All of the articles I have seen are for cars equipped with SRS seat airbags, and mine did not have those. The wiring harness to the seat only contains a red, black, and orange wire.
I tried putting the 2.2 ohm 1/2 watt resistor between the orange wire and black (ground), then running the 7 second "on"/5 second "off" 3 times, but all that did was put me into a mode that looked like it was showing a code. When I looked up other tutorials, the code that my car was giving me seemed to be that the passenger sensor wasn't hooked up. I thought this is what the resistor was supposed to mimic.
Can anyone help me out? I have no problem totally disabling the airbags (so long as the light is off), as I will be going to a removable steering wheel soon anyways.
Old May 13, 2014 | 03:42 AM
mwcarroll's Avatar
mwcarroll
Anyone?
Old May 13, 2014 | 02:28 PM
fzero's Avatar
fzero
I had the same issue when I installed my recaros, I just used my spare passenger seat and ripped out the passenger airbag weight sensor in the seat and ziptied it under the new seats. Light is off
Miguel Albanez
Oct 17, 2022 10:13 AM
NiLL
Nov 29, 2021 02:26 PM
Vigman
Nov 17, 2015 04:34 AM
issyz
Sep 12, 2015 04:18 PM
