Installation Help: Black Projector Headlights on a '04
Old Nov 17, 2016 | 03:09 AM
04Zoro's Avatar
04Zoro
Default Installation Help: Black Projector Headlights on a '04
I recently bought a '04 350z base model in Black w/ Black interior.
My overall plan for this car is to black it out...So right away I started ordering aftermarket parts for it.
What I am trying to figure out at this moment is how to install the front headlights.
The Female plugs on my car have a "8-pin" design...While the plugs on both of the headlights have a Male "6-pin" design.
Help! Does someone have a link to an aftermarket adapter or a harness that is made to make this modification work? Or would it have to be a cut/spice type of job? This is my first buying aftermarket parts that are not exactly plug & play so any input would be greatly appreciated.
Thanks!
Old Nov 17, 2016 | 03:46 AM
travlee's Avatar
travlee
Master
nope, never been asked before in the 13 years your car has been out..... the search function works wonders
Old Nov 17, 2016 | 03:56 AM
04Zoro's Avatar
04Zoro
Thanks!
BTW nice '08 Corvette
Old Nov 17, 2016 | 04:01 AM
travlee's Avatar
travlee
Master
dammit since you complimented the car, i will throw ya a bone
try starting here
https://my350z.com/forum/exterior-an...eadlights.html
Old Nov 17, 2016 | 04:02 AM
04Zoro's Avatar
04Zoro
Took your advice & used the search box already
Old Nov 17, 2016 | 04:04 AM
travlee's Avatar
travlee
Master
you will get better results if you do this. using google type whatever you want to search for, and then add site:my350z.com after it.
Old Nov 26, 2016 | 02:28 AM
mcubed45's Avatar
mcubed45
Your car has HID's. Those lights are halogen.
03-05 had either halogen or HID low beams. Both had halogen hi-beams
06-08 only has on type of HID headlight
6pin = halogen (03-05)
8pin = HID (03-05)
Old Nov 26, 2016 | 02:31 AM
mcubed45's Avatar
mcubed45
BTW you could've just upgraded to the nicer 06-08 lights. They don't have reflectors for the hi-beams or low-beams so they're already more blacked out:
https://conceptzperformance.com/depo...h2_p_17221.php
Old Nov 27, 2016 | 10:05 AM
04Zoro's Avatar
04Zoro
$499! Sheesh...I was looking for a more cheaper alternative.
Had no idea my car was equip w/ HIDS but it all makes sense now.
I'm going to look around & see if I can find a pair of cost efficient "BlackOut" HID Headlights.
Old Nov 27, 2016 | 10:18 AM
04Zoro's Avatar
04Zoro
Sorry to come off lazy or dumb; Would these work with my application?
http://www.ebay.com/itm/Black-Fits-2...pYHTuh&vxp=mtr
Old Nov 27, 2016 | 11:53 AM
mcubed45's Avatar
mcubed45
Honestly if you don't want to upgrade to the 06-08 style headlights, you're better off just baking open your stock lights and painting them black yourself. Otherwise you're basically paying $200 for some black paint. Blacking out your stock lights can be done for less that $10.
The 06-08 lights are a pretty nice upgrade. OEM go for over $1k for the pair so when the depo's came out a few years ago it was quite a bargain. If you're going for a "blacked-out" look, 06-08 is the way to go. You can even open up the 06-08 and black out the chrome bits without losing much output (just the turn signal and parking lights).
https://my350z.com/forum/body-interi...light-mod.html
A bit cheaper on ebay and other sites:
http://www.ebay.com/itm/DEPO-BLACK-D...NSFGoy&vxp=mtr
http://www.rev-motion.com/collection...eadlights-pair
Old Nov 27, 2016 | 12:59 PM
04Zoro's Avatar
04Zoro
At first it was all about "Blacking the vehicle out"
Now its basically revolving around being cheap...What I'm really searching for is the cheapest alternative.
Old Nov 27, 2016 | 06:54 PM
mcubed45's Avatar
mcubed45
Is there a problem with your stock lights? Just paint them.
Old Nov 28, 2016 | 03:02 AM
92K1500's Avatar
92K1500
I hear you can pick up Honda Civics for a reasonable price.
Old Nov 28, 2016 | 03:08 AM
travlee's Avatar
travlee
Master
balla on a budget
Old Nov 28, 2016 | 12:28 PM
04Zoro's Avatar
04Zoro
The stock lights were broken in a accident.
I purchase the car with that way.
Good running car...just needed a front bumper and 2 headlights.
Old Dec 7, 2016 | 06:21 AM
04Zoro's Avatar
04Zoro
Arrow ...
I decided to return the aftermarket "Black Out" headlights to the seller.
I am now waiting on a refund for the amount that I spent on them.
Since only the Left headlight was damaged on the car, I plan to purchase a used headlamp for that side via Ebay.
Right now I am more focused on getting it back together & on the road more than anything.
I will later take the initiative of "smoking" the factory lights, but for now I will repair the Z back to its oem form.
Searched Ebay & came up w/ these: http://www.ebay.com/itm/NISSAN-350Z-...VX4EM2&vxp=mtr
Of course, there were cheaper lights listed but most of those were either scuffed up on the lens or have broken tabs on the backside.
Since I plan to ride w/ a oem look for a while, I wanted to opt for a clean headlamp w/ little to no damage.
Old Dec 8, 2016 | 10:35 AM
Blurvision's Avatar
Blurvision
rockauto.com sells OE look replacements.
Old Dec 10, 2016 | 09:36 AM
04Zoro's Avatar
04Zoro
Thanks!
http://www.rockauto.com/en/catalog/n...0z.com+URL+%2F
http://www.rockauto.com/en/moreinfo....431982&jsn=389
Old Dec 10, 2016 | 09:52 AM
04Zoro's Avatar
04Zoro
Took the parts # from RockAuto.com & used it to search Ebay.
Ending up finding this LH Headlamp for only $89.98!
http://www.ebay.com/itm/HID-Headligh...5YQu69&vxp=mtr
The photos are detailed, which shows the 8-pin Male plugs that are needed to connect to my car.
Also says that they are for HID (Xenon) equipped 350z's...03-05.
However the assembly does NOT include a bulb; Does anyone know what size/type bulb these headlamps use?
Thanks in advance.
