Number of Bulb of High Beams
Old Feb 17, 2004 | 08:21 PM
silverstoneTT's Avatar
silverstoneTT
Default Number of Bulb of High Beams
Sorry if this is a repost, just looking for a quick answer. What is the number of the bulb that the Z has for a high beams?
I mean like 9005 or what not? Im interested in just buying a pair of those Sylvania lights that are supposedly white for the high beams.
Thanks
Old Feb 17, 2004 | 08:24 PM
ares's Avatar
ares
Veteran
H1-55W
Old Feb 17, 2004 | 08:25 PM
silverstoneTT
Hmmm thats what I read in the manual... I thought those lights also had a different number also though....I guess I was wrong. Thanks though
Old Feb 18, 2004 | 09:33 AM
silverstoneTT
Oh no, okay I found that Sylvania does make that bulb number. The moderator can delete this if you want.
Old Feb 18, 2004 | 02:48 PM
FLY BY Z's Avatar
FLY BY Z
Woah, the high beams are H7's. I have some installed.
silverstoneTT
The manual says H1 though
Old Feb 18, 2004 | 03:03 PM
KornerCarver's Avatar
KornerCarver
It depends on the model. Base models have H-1 high beams and the HID equipped cars use H-7 high beams.
Les
Old Feb 18, 2004 | 03:14 PM
FLY BY Z's Avatar
FLY BY Z
And silverstone, you, my friend, have HID's in that Touring. Therefore, your Hi-Beams are H7s. Read the manual once more.
Old Feb 18, 2004 | 03:34 PM
ares's Avatar
ares
Veteran
aye, I got it off the sylvania bulb guide, guess they missed that little distinction. sorry.
Old Feb 18, 2004 | 05:15 PM
silverstoneTT
Oh ok thanks for that bit.Guess I should have looked more closely. Will look into buying the lights soon.
Old Feb 21, 2004 | 10:47 AM
Track's Avatar
Track
Coolness. If you find some Ultra Whites or Plasma's please let us know where you found them. I've been looking for those (for my high beams) ever since I got my Z.
Additionally, I would also like to replace the peripheral bulbs in the headlight assembly (on HID equipped Z's) with the same.
Anyone got any ideas?
Old Feb 21, 2004 | 06:41 PM
silverstoneTT
Peripheral bulbs? Parking lights?
Still need to go get the high beams although I may go cheapo on them cause i Dont want to spend 40 on them
Old Feb 21, 2004 | 06:50 PM
Mr B's Avatar
Mr B
I thought even on base models, they're H7 and the driving light is H1.
Old Feb 21, 2004 | 07:41 PM
Track's Avatar
Track
I should have been more clear.
I don't know what else to call them: I'm talking about the third bulb in the HID's housing. These "third" lights are smaller and are angled inwards where they shine against a reflector that scatters this light to the periphery.
This light is a great idea to address the only legitimate (IMO) complaint about HID lights: that they are too "focused" and straight ahead leaving your peripheral vision darker thus creating a type of "tunnel vision" effect at night. Nissan, in their divine wisdom ( ), fixed this problem with those little bulbs that shine diffused light off into the corners to fill in the "gaps" left by the projected HID light.
Anywho, wouldn't it be cool to replace those with hyperwhites or ultrawhites (something with a color temperature somewhere between 4000k and 5000k)???
For instance, I like the color of APC's Ultrawhite (4000k) Simulated HID bulbs. Wouldn't they look great added to our true HID lighting systems? It seems as if they would look better than the "yellowish" bulbs used by the factory to light up the sides of the road on our HID equipped Z's.
Just a thought.
Old Feb 21, 2004 | 07:44 PM
silverstoneTT
Hmmm I think your referring to the parking lights which arent meant to spread more light as they dont put out enough light. the best current alternative is Ares LED lights. But they stillarent amazingly bright, just look nicer
Old Feb 21, 2004 | 08:17 PM
Track's Avatar
Track
I just can't explain anything right tonight. And even worse, I've not yet even gone out to "party" ... yet.
If you go out and look inside your HID housing, you will see you have 4 lights.
1. The HID projector
2. The high beams
3. The parking lights on the side (amber)
4. The "peripheral" lighting bulbs to with I was referring
Now, for all I know these little white lights may also be responsible for illuminating the amber parking lights from behind, as these side lights also turn on when the parking lights turn on. If these lights are the source of illumnation for the parking lights then indeed we are talking about the same bulb. It may serve two purposes.
Anywho, seeing as this bulb is visible and provides side lighting, what is the name of it and is it available in an "ultra white" or simulated plasma HID, etc.?
These bulbs are small "white" halogen-type bulbs that shine against a reflective plate that scatters the light outwards (in a fan-like pattern) to give the driver more peripheral vision. I assume the indirect lighting and the method of scattering it is an effort to provide light to the corners without annoying other drivers as they pass. They also may be the source of light for the parking lights; I do not know as they seem to be illuminated from behind. Is it the same bulb?
If you haven't noticed, I know nothing about the lights on this car.
Did that make more sense?
Thanks for helping.
Old Feb 21, 2004 | 08:20 PM
silverstoneTT
lol you cant explain and Im so tired i dont understand. I cant go out now but i understand the first two. The amber bulb is the turn signal. the small one off to the side facing inwards is the normal colored bulb which is the parking light. Ill check tom. though. Anyone else have any idea?
Ahhh im gonna go to bed. i cant think about lights any more tonight
Old Feb 21, 2004 | 08:29 PM
Track's Avatar
Track
Ah, I see. The white bulb is also considered part of the parking lights! I considered the parking lights to be just the amber parts on the side; I didn't know parking lights were allowed to be clear.
Are those little white bulbs available in a plasma type ultra white from someone like APC? I'd like them to better match the HID color. Does anyone know the part number for that bulb? It really does serve a useful function since HID's are projected so narrowly.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
aboodi
Oct 28, 2015 02:07 PM
