Can you turn window motors?
Old Apr 19, 2019 | 09:22 PM
Waffeey's Avatar
Waffeey
Default Can you turn window motors?
Hey all I am in the process of replacing, well, reinstalling my window motor because it two of the three bolts and backed out and the motor was so loose it had started skip and strip the 3/8" drive. The problem is I cannot get the motor drive to turn in order to align it to the window regulator hole. I tried turning the motor by hand and the regulator with an extension but neither budge. Should I just replace my window regulator or is there a way to align the two? Thanks in advance.
Old Apr 20, 2019 | 01:19 AM
Waffeey's Avatar
Waffeey
Ended up having to take the motor apart to align the drive to the regulator. Cleaned it up inside and after much pain managed to clear the brushes and put it all back together. Boom fixed.
Old Apr 20, 2019 | 05:14 AM
travlee's Avatar
travlee
Master
For now....
Old Apr 20, 2019 | 05:22 AM
dkmura's Avatar
dkmura
General & DIY Moderator
What Trav is referring to is the fact that many Z owners have tried cleaning and reassembling window motors, only to have them fail again in short order. Search the forums and you'll find multiple threads about this. Lesson is to fix it right with a new motor and be done with it. Unless you've grown FOND of pulling your door panels off repeatedly...
Old Apr 20, 2019 | 09:51 AM
Waffeey's Avatar
Waffeey
well I was quite fond of being able to drive my car to work today and not have to get another ride. Also like I said my motor never had any issues it had just fallen out of the drive hole in the regulator.
Old Apr 20, 2019 | 06:10 PM
travlee's Avatar
travlee
Master
Please dont double post
https://my350z.com/forum/2003-2009-n...-to-motor.html
azaz
Nov 19, 2004 03:15 PM
lovetoclown
Jul 27, 2004 10:02 AM
syf0n
Jul 22, 2004 12:01 PM
spinninbackfist
Aug 28, 2003 02:49 AM
