Nrg quick release and hub on a grip royal wheel off center?
Old May 10, 2019 | 02:54 PM
Eddie Gleason's Avatar
Eddie Gleason
Default Nrg quick release and hub on a grip royal wheel off center?
So I have the wheel installed but seems to be sitting at around 2 o’clock and the hub is at 12 o’clock any way to fix this I ordered the nrg spacer I read that it works but I’m not sure any advice or insight would be greatly appreciated thanks!!
Old May 15, 2019 | 11:14 AM
BQPham's Avatar
BQPham
Same here. The NRG Hub i think is off. I matched it up to the center marking on the steering spline, but my wheel still sits at more like 1-1:30 instead of 2 o'clock. I will likely just get it realigned, but i believe it is an NRG hub issue.
Old May 15, 2019 | 03:37 PM
Eddie Gleason
Default Fixed it
I got the nrg spacer and it fixed it just took me a little bit to figure out which way it needed to be sitting but the wheel is straight as an arrow now I recommend the spacer I got mine on amazon for 20$
Old May 16, 2019 | 05:46 AM
BQPham's Avatar
BQPham
Thanks man was this the one you got?
Amazon Amazon
I'm a little unsure if i should use this since i shaved my Nardi Horn to fit lol. Others complain about this putting their wheel off a degree or two, but i assume since ours were both off this should help to straighten it
Old May 16, 2019 | 05:50 AM
Eddie Gleason
Yeah that’s the one It should fix it and make it straight... grip royal has a spacer/ adapter that does the same thing but it’s 60$ but either one I would imagine will get you straightened up.. let me know how it goes
Old May 16, 2019 | 06:41 AM
BQPham's Avatar
BQPham
Awesome thanks man just submitted the order, hopefully that half inch space isn't too big of a deal for me. Hopefully this sorts it out! Will update on results.
Old May 16, 2019 | 06:49 AM
coletrickle74's Avatar
coletrickle74
Saving this for later. Thanks!
Old May 22, 2019 | 06:28 PM
BQPham's Avatar
BQPham
Did not work out for me as of now. Say the hub mark is lined up with the top dead center mark on the steering spline. This puts my steering wheel at 3 degrees to the right for example. When bolting the hub spacer, it moves the mounting over to the right another 3, so 6 total degrees to the right.
I will try to unbolt the NRG hub, move it back counter clockwise one tooth, then install the hub spacer and see what happens.
Old Jun 12, 2019 | 04:52 AM
BQPham's Avatar
BQPham
Update, i moved the hub back counter clockwise one tooth and added the spacer, the wheel is still slightly off to the left. Will need to do an alignment.
On the bright side, i've been running a NRG Short Hub with NRG Quick Release with Nardi Personal Neo Grinta steering wheel. The horn never really fit correctly due to the two wires for the horn. With the spacer, it gave it enough space and my horn sits perfect now lol.
potato
Interior
May 5, 2015 07:01 AM
na12uto
Mar 13, 2014 07:23 AM
drtrey
Interior
Mar 2, 2014 05:03 AM
Guilty1s
Interior
Mar 22, 2012 10:58 AM
