Help Drivers door lever sticks
Old May 13, 2020 | 02:22 PM
bj-99's Avatar
bj-99
Default Help Drivers door lever sticks
The drivers door exterior handle sticks badly when the window is up. Works fine with the window down. The lever most of the time does not engage to window interlock & the handle needs to be jerked vary hard. Always work fine from the inside handle. Please advise.
Old May 17, 2020 | 06:01 PM
calvin.w's Avatar
calvin.w
I advise you put it in rice
Old May 17, 2020 | 06:03 PM
calvin.w's Avatar
calvin.w
Nah but seriously, go to Amazon and get a new door handle just to test. If the new handle works fine, then the old one is in the process of failing. The Zs exterior handles are known to eventually fail and need replacing.
Old May 18, 2020 | 06:39 AM
travlee's Avatar
travlee
Master
i would pull off the door panel so you can see the rods for the handles, see if something is out of place when the window is up
daytona7135
Oct 18, 2012 10:36 AM
Lochness
Sep 19, 2012 12:01 PM
Mo Zee
Oct 31, 2010 09:57 PM
yanotkaj
Jan 18, 2006 06:25 PM
ricka
Jan 14, 2006 09:46 AM
