As this kit emits white light which turns amber when the turn signals are activated, I'm wondering:
Can this be wired such that it ONLY emits amber/yellow light w/o the turn signal function? In other words - simply as an amber/yellow LED fog light kit?
Is there any other similiar kit out there that outputs amber/yellow light instead of white?
It wouldn't really be a "fog light kit" but more of just an illuminated side marker. Sure, you could wire it differently so that it only illuminates amber, but that seems like it would be a waste to get that switchback kit and only use half of the functionality. With some switchback kits, the amber signal is driven at higher power so if it is illuminated constantly, then you risk burning it out.
If I were you, I would get some HD amber LED strips from Diode Dynamics, open up your stock reflectors or get some clears and put the LED strip in there. Wire it up to either your parking lights as a trigger or an accessory so it would function as a DRL.
I have ijdm led sidemarkers for several years with zero problems - it is a good product.
You can rewire them for sure , but trust me - you’ll like them as they are.
The early Z33 bumper design isn't very conducive to forward facing light. Those reflectors are angled to the sides, if you look at the IJDM and others for 03-05, they poke out of the bumper to face forward. They look wonky especially when off. The alternative is to place fog ligths in the radiator opening, but you could do that with any generic light at the expense of radiator intake real estate.
Not to argue semantics, but being a lighting nerd, I have to clarify some things. The sidemarkers are not fog lights. The clear white strip that you see on the Z34 front bumper is not a fog light. It's a sidemarker and a daytime running light. As Freise mentioned, you can get any generic fog light kit, LED light bar, etc. and mount it on the bumper and that would be a fog light. A true fog light beam pattern will be wide and not as focused as a driving beam. A DRL or illuminated side marker is not going to have a wide beam pattern like a fog light. You will not be able to install fog light in the OEM sidemarker opening on your Z33 front bumper.
