Installing shift boot (howto with pics)
Old Mar 2, 2004 | 01:07 PM
sbonell's Avatar
sbonell
Chris,
Can't find information about locking shift mechanism when removing shift **** in the service manual. Can you post detail if you have it please? All I can find is...
"REMOVAL
1. Loosen the shift **** to remove the control lever.
CAUTION:
Be careful not to damage the shift ****.
2. Push back the boot, remove control lever assembly mounting
bolt, and separate control lever assembly and control rod
assembly.
3. Remove console finisher. Refer to IP-12, "Removal and Installa-tion"."
working from
Edition: June 2002
Revision: June 2002
Publication No. SM3E-1Z33U0
Thanks
Stuart
Old Mar 2, 2004 | 01:27 PM
Conceyted's Avatar
Conceyted
Originally posted by sbonell
Chris,
"REMOVAL
CAUTION:
assembly.
working from
Edition: June 2002
Revision: June 2002
Thanks
Stuart
http://www.provtech.co.uk/350z/Nissan_TSB_MT02-004.pdf
there is the link to the pdf which holds the correct way to remove the shift ****. It has some nice diagrams as well!
Old Mar 2, 2004 | 01:28 PM
Conceyted's Avatar
Conceyted
here is what i was talking about...
Old Mar 2, 2004 | 03:26 PM
350ed's Avatar
350ed
Professional
Wonderful. THANKS!
Old Mar 2, 2004 | 11:28 PM
sbonell's Avatar
sbonell
Conceyted,
Thanks - pretty important we get that in. I didn't hear back from the admin here. It would be great to get this step added into the top of the thread.
Chris - can you tell me what version of service manual you're working from. I think it appears at the top of the page. Seems like they've made some updates.
Can anyone help?
Stuart
Old Mar 3, 2004 | 12:05 AM
sbonell's Avatar
sbonell
OK - I found the answer. This info. is in a technical service bulletin.
Whole bulletin can be found here:
http://www.350zgt.com/forums/index.php?showtopic=63
Cheers
Stuart
Old Jul 18, 2004 | 07:37 PM
ISH's Avatar
ISH
Did you guys apply any threadblocker to the shift lever?
THE TSB mentions applying a High Temperature High Strength Threadblocker Red to the threads of the shift lever.
Old Jul 18, 2004 | 08:42 PM
slay2k's Avatar
slay2k
Can one of you tell me where I can get that silver ring that goes on the outside on top of the shift boot when you're all done ? I know it comes with the car... but I don't think I have it anymore after I've had a shop switch my shift boot twice.
I only have a black plastic thing on the outside showing, which I'm guessing sits underneath this silver cover.
Someone wanna help me out ? Plz ?
Old Jul 19, 2004 | 12:27 AM
sbonell's Avatar
sbonell
Default Thread lock and silver ring
ISH - up to you. Threak lock will make sure shift **** doesn't work loose and is part of the official procedure. In my case, it was tight enough to stay put and I decided to leave it out to make life easier if I do other changes.
As it happens, I subsequently changed to a Nismo shift **** so glad I left thread lock off.
slay2k - your dealer/shop lost a bit of your car? first place I'd go is back to them. Otherwise, its a Nissan part so local dealer or call up Courtesy or Performance Nissan for help.
Stuart
Old Jul 19, 2004 | 06:09 AM
Reggi914's Avatar
Reggi914
thanks sooo much for this!
Old Jul 19, 2004 | 07:29 AM
sbonell's Avatar
sbonell
You're welcome.
Now you've got your car, you need to get that Avatar updated sharp-ish
Stuart
Old Sep 4, 2004 | 01:10 PM
Z BOY's Avatar
Z BOY
Default Re: Installing shift boot (howto with pics)
Just installed a redline shift boot. Thought some pics might be useful here. Apologies if its not in the right place, I couldn't find a HowTos area.
1. Remove shift **** by wrapping a towel/cloth around stem of shift **** and using a wrench to loosen. Unscrew and remove.
Ohmygod, i can't even get the friggin shift **** off, and i'm scratching it!!! I'm turning to the left. It turns reluctantly but doesn't loosen. Pls help!!!
Old Sep 4, 2004 | 01:25 PM
Z BOY's Avatar
Z BOY
SERVICE MANUAL SAYS NOT TO REMOVE **** THIS WAY, THAT IT WILL DAMAGE TRANSMISSION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!THIS PAGE NEEDS TO BE PULLED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!IF MY TRANSMISSION IS ****ED UP, THERE WILL BE HELL TO PAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 4, 2004 | 03:21 PM
Reggi914's Avatar
Reggi914
Default Re: Re: Installing shift boot (howto with pics)
uh... did you not read this whole thread?
Old Sep 5, 2004 | 05:45 AM
sbonell's Avatar
sbonell
like he said.
FYI - I did request that mods update or enable me to, but didn't hear anything back.
The Howto on Redline and Courtesy sites was updated along while back.
Stuart
p.s. by the way, your ! key seems to be stuck
Old Sep 5, 2004 | 09:37 AM
Z BOY's Avatar
Z BOY
Whew! Used the tsb to remove the shift **** properly. The radiator hose stopped further damage to the bottom edge of the ****. Used a black magic marker around the bottom of the **** to hide the scratches caused by trying to used a towel to remove it. Problem solved. My bright-orange boot is installed. Matching seats and steering wheel leather next!
Thank you, moderators, for the frustration and the scratches.
Old Sep 5, 2004 | 10:26 AM
Hazade's Avatar
Hazade
nice writeup man.. i love how-tos with pics!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
pr_350z
Oct 1, 2015 05:03 PM
