Sparco Grip pedals installed *pics*
Old Apr 1, 2004 | 11:30 PM
35oZephyR's Avatar
35oZephyR
Default Sparco Grip pedals installed *pics*
Another alternative mod for you base owners..or if anyone wants to change their pedals.
I wanted to get the OEM "drilled aluminum" pedals for awhile now but come to realize that it was actually pieces of aluminum laminated on rubber. Plus: OEM sets are well over 60 bucks! About 75 bucks in most dealerships.
I picked up the Sparco grip pedals online for like $42 bucks most places sell them for a little over 50 bucks. They're actual aluminum pedals with inserted rubber grommet thingies for extra grip. I removed the stock rubbers (that come with the base) and surprisingly they weigh almost as much as these Sparco pedals. Good thing they match the OEM dead pedal I bought from Courtesy awhile back.
BUT!! What you save in some cash you make up for the labor!!
So if you want some genuine racing pedals be prepared to work for it...you need a good drill/ patience and a steady hand! Drilling them into the metal backing was a PIA. I recommend aligning beforehand with automotive 3m before drilling.
The payoff is well worth it...the little grip thingies make sure your feet won't slip even though you're only applying a cm worth of sole! I can't slip even if I try.
From the fourth pic you can see i've found out new funky ways to "heel toe" or should I say "toe side" with these pedals.
Old Apr 2, 2004 | 02:55 AM
joust75's Avatar
joust75
I was holding my breath thinking you got those cheezy pedal covers, but those look like replacements.
They look good! Nice mod Antoine!
Old Apr 2, 2004 | 07:00 AM
Alberto's Avatar
Alberto
Cranky FI Owner
They do look pretty good....I didnt know the base model didnt come with the aluminum pedals?
Old Apr 2, 2004 | 07:10 AM
slay2k's Avatar
slay2k
You know, I was thinkin about doing that even though I already have the stock aluminum pedals... my reason was to extend the gas pedal more to the left for heel & toe... but those look kinda far apart.
Old Apr 2, 2004 | 07:11 AM
ranger5oh's Avatar
ranger5oh
That gas and brake look so far apart, looks hard to heel toe. I like em, but I think for $20 more I woulda gone stock.
Old Apr 2, 2004 | 09:54 AM
mofoz's Avatar
mofoz
i was actually thinking about getting these same ones. I think that if they are alitle farther apart, it would be easier to heal toe for people like me with size 13 shoes.
Old Apr 2, 2004 | 01:07 PM
aaaaa's Avatar
aaaaa
i think i will stick to my factory aluminum pedal
Old Apr 2, 2004 | 04:13 PM
35oZephyR's Avatar
35oZephyR
Hahah I was always against those pedal covers...I can't imagine having them come off on me.
Old Apr 2, 2004 | 04:22 PM
35oZephyR's Avatar
35oZephyR
It's actually not that far apart. I have a 10 in foot and could heel toe pretty easily because of the extra extended tab on the left corner of the gas pedal. I made sure the pedals were in spec as far as distance goes. They give you this little cheesy manual that shows you the minimum distance between each pedal.
I would have gone stock too but I didn't like the fact that they were just rubber pedals wrapping around the pedal frame. I've driven a Z with the OEM aluminum pedals and the Sparcos grip a hell of a lot better and each pedal is significantly bigger. Of course all my kicks have gum soles so that might be a huge factor too.
If I had the OEMs already I wouldn't bother...but if you love heel toeing then these make it ALOT easier.
cheers.
Old Apr 2, 2004 | 04:35 PM
35oZephyR's Avatar
35oZephyR
It might be how the pics are angled but I have my gas and brake a little over 50mm apart. The minimum is 50mm and the max is 100. (the pedals are a little depressed on the fourth pic). Thats about 2 and a quarter inches apart I think. So a little closer than stock (which is about 60mm?).
The beauty of installing aftermarket is that you can set them however you like. I actually had the clutch set far to the left so I can pivot my foot from the dead pedal. I did alot of "pretend driving" while I had the pedals mounted on with 3m to get the angles just right. Alot of "science" went into it!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
