Emblem Remover
Old May 26, 2004 | 08:45 AM
estes's Avatar
estes
Default Emblem Remover
Going to remove trunk emblem. Need some solvent to remove 3M permanent adhesive that won't effect paint. Contacted 3M no reply.
Old May 26, 2004 | 08:58 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I think most people just use 'Goof-off', I think you can get at Wal-Mart or somewhere like that.
Old May 26, 2004 | 09:48 AM
Demolition Man's Avatar
Demolition Man
be carful with goof-off near any interior plastic. it melts it pretty badly. worked at a car wash for 2 1/2 years, and we ended up going to simple green for stains and stuff, because goof off was just eating interior plastic away
Old May 26, 2004 | 09:59 AM
estes's Avatar
estes
How about the regular car paint on the trunk, will it effect that? remember this is permanet adhesive and what ever is left will probably a 1/16 of an inch left on the trunk after emblem is removed.. thanks
Old May 26, 2004 | 10:04 AM
estes's Avatar
estes
Old May 26, 2004 | 10:34 AM
estes's Avatar
estes
Old May 26, 2004 | 10:45 AM
ronald_m's Avatar
ronald_m
NO nee to use Goo gone or any adhesive remover just use a blown dryer to heat up the emblem then use a floss(sp?) to remove the emblem or if you're real careful you can use flat head screwdriver wrap in cotton shirt.the technique is to heat up the emblem.
Old May 26, 2004 | 11:41 AM
Phatmitzu's Avatar
Phatmitzu
I just used fishline and my finger nail?
Old May 26, 2004 | 12:00 PM
mgl's Avatar
mgl
dental floss and a your finger is all you need.
Old May 26, 2004 | 12:30 PM
estes's Avatar
estes
Thanks that's great info, I 'll try that. I will order the new Z emblems.
Old May 26, 2004 | 01:29 PM
Brandon@Forged
I misunderstood, you weren't clear enough, I thought you had already taken the emblem off and was looking to get the adhesive off. Yes, like stated, heat it up with a blow dryer and use dental floss to remove it.
Old May 26, 2004 | 03:21 PM
JokerDev's Avatar
JokerDev
I used fishing line and a blow dryer to remove the emblem, then used this stuff called goo gone to remove the adhesive. it is a citrus based remover, and didn't hurt the paint. Then I used rubbing alcohol to completely clean the surface before I attached the new emblem. Worked out great. If you order the Z emblems from courtesy, ask them to send you the 3m adhesive backings, they are a lot better
Old May 26, 2004 | 06:04 PM
estes's Avatar
estes
Thanks for the tip on the 3m backing, I'll be sure to ask for that.
Old May 26, 2004 | 06:10 PM
estes's Avatar
estes
Old May 27, 2004 | 12:26 AM
FLZ's Avatar
FLZ
Default Follow JokerDev's instructions
Real easy to remove. No agents at all.
Old May 27, 2004 | 08:00 AM
orhanz33's Avatar
orhanz33
aren't there any holes left behind when you remove the nissan emblem?
Old May 27, 2004 | 11:31 AM
estes's Avatar
estes
They are glued on. No holes . Estes
Old May 27, 2004 | 12:08 PM
KrazY-2K's Avatar
KrazY-2K
I thought the Coupe had holes on the rear hamburger emblem? I remember a thread where someone stated that only the roadster doesn't have the holes.
Old May 27, 2004 | 01:07 PM
estes's Avatar
estes
I'll let you know when I get it off.
Old May 27, 2004 | 05:07 PM
orhanz33's Avatar
orhanz33
there must be holes... if there wasn't i know i'd see a lot more pics of Z's w/ no nissan emblem on the hatch
