best type of LED
Old Jul 1, 2004 | 07:38 AM
SangWL's Avatar
SangWL
Default best type of LED
i had piaa extreeme white LED wedge bulbs inside the head light assembly, but they are starting to flicker, anywho, i'm wondering what your opinions for the longest lasting, best white quality LED wedge bulb there is.
thanks guys
sang
Old Jul 1, 2004 | 02:19 PM
ares's Avatar
ares
Veteran
Old Jul 1, 2004 | 08:02 PM
MacGyver's Avatar
MacGyver
ares,
Your products will sell a bit faster if you actually MENTION them instead of merely hopping up and down
Old Jul 1, 2004 | 09:22 PM
ares's Avatar
ares
Veteran
link in my sig has pics and info about it.
Old Jul 2, 2004 | 12:13 AM
juhko's Avatar
juhko
Wow, I thought LEDs were supposed to last forever - is this just a fluke ares?
Old Jul 2, 2004 | 06:07 AM
ares's Avatar
ares
Veteran
probably, every LED Ive ever seen has a 10,000 hour life(cept for some extreme output that piaa is not using, and its still 1000+ hours)
manufacturing has imperfection and Im sure they dont all make it 10,000 hours, but even if you cut that by a 10th, thats a year of use. and that shouldnt be acceptable anyway. Id doubt piaa is using LEDs that crappy that theyd fail so soon. they should go dim anyway, not "blow". my guess is they got zapped with some static somewhere; these are static sensitive just like your PC; should ground yourself when working with them.
Old Jul 2, 2004 | 06:44 AM
MacGyver's Avatar
MacGyver
Well, don't forget that many companies will overdriver an LED for high light output. In their eyes, even if they shorten the LED's lifespan by an order of magnitude, by the time it blows you'll have either moved on to something bigger and better, or the warranty has expired and you'll need to buy another one anyway. Poor business decision or morals, either way.
Old Jul 2, 2004 | 07:17 AM
DIGItonium's Avatar
DIGItonium
Not just that... I've taken apart these cheap things. Most likely the resistor they use is super small and it burns out easily and the solder work is crap. The LEDs, themselves are pretty cheap too - inconsistent colors and brightness.
lapham3
Oct 7, 2022 03:15 PM
dcains
South East
20
Feb 22, 2016 10:27 PM
Mw870
Oct 2, 2015 08:23 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
leonchus
Sep 29, 2015 07:04 AM
