Parking Light Problem/FUSE
Old Aug 5, 2004 | 09:25 PM
350zOnJuice's Avatar
350zOnJuice
Smile Parking Light Problem/FUSE
Hey guys . i would like to know if anyone knows what fuse it is for the yellow bulb inside the headlight which is the parking light bulb? I want to make this bulb not work (therefore) remove fuse because I just want my HID'S on instead of the annoying yellow light.. So please guys if you know let me know where this fuse is ... thank you
Old Aug 5, 2004 | 11:18 PM
John@Victory's Avatar
John@Victory
buy the white led lights from ares....perfect match to the hid and they are very affordable
any how the fuse is in a fuse box behind your battery....heve to pull the battery cover housing off to see it....
Old Aug 6, 2004 | 04:39 AM
350zOnJuice
Ok i see the fuse box as soon as i remove battery cover housing but those fuses dont say headight/parking light they only say / vdc/horn relay/abs/ etc.. do i have to remove batter to see what your talking about , because there underneath the blackhousing those fuses dont correspond to what im looking for??
thanks
Old Aug 6, 2004 | 04:52 AM
ares's Avatar
ares
Veteran
you gotta remove the plastic fasteners that hold the shroud around it. pull the shroud and youll see a second box of fuses behind and below the battery, its a tall box rather than long.
Old Aug 6, 2004 | 05:30 AM
350zOnJuice
Still dont see anything ........ am i supposed to remove battery. I do see a fuse box when i remove the battery placstic housing , which has also a black top on it with fasteners , i take that little top of but its fuses and relays but for ABS/VDC/HORN but not for headlight etc. Am i supposed to remove the battery?
Old Aug 7, 2004 | 03:06 PM
John@Victory
you do not have to remove the battery....just the shroud...
the top of the lid on the box is probobly 2 1/2 " x 3 1/2" but it is long going down towards the battery ...pull that whole cover off and look at those fuses....dont know if they are labeled as running lights or not...been a long time since i blew one...just pull out the fuses and look for the blown one
Old Aug 7, 2004 | 07:36 PM
ares's Avatar
ares
Veteran
its behind the battery, between the battery and firewall. to verify, you removed the black cover AROUND the circle cover that comes off easily. if so, you should have seen it to the rear of the battery, towards the passenger door.
Old Sep 3, 2024 | 09:58 AM
Used tofc3s's Avatar
Used tofc3s
Anyonee know where I. This box the fuse is. None of the labels indicate it. I was told it's number 71 and have t looked again but I do t re.e.ber seeing it there
Old Sep 3, 2024 | 11:00 AM
travlee's Avatar
travlee
Master
Nobody has posted in this thread for 20 years
Old Sep 3, 2024 | 07:06 PM
Used tofc3s
20 years or not someone must know the answer..
Old Sep 4, 2024 | 04:40 AM
Heel Til I Die's Avatar
Heel Til I Die
Correct. I posted it in your other thread you made with a diagram of the battery removed, or you could read the previous posts in this thread indicating that you need to remove the plastic shroud around the battery.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
ablaine
Nov 29, 2016 10:13 AM
samansharif
Sep 25, 2015 12:31 PM
