Question on Stillen 2 nose (or similar)
Old Sep 28, 2004 | 01:51 PM
zh.guitar's Avatar
zh.guitar
Leave your mark!
Question Question on Stillen 2 nose (or similar)
I am considering the Stillen 2 fascia. I was wondering.
Do you NEED to use a grille of some sort?
All the pics show an empty hole in front of the radiator. Of course it says "Stillen" on the radiator.
Is this ok with stock radiator and if I don't need a grille insert should I have one?
Old Sep 28, 2004 | 07:24 PM
zh.guitar's Avatar
zh.guitar
Leave your mark!
Stillen's website mentions :
Other optional features include: Speed grilles made specifically for the center and lower vents, brake cooling ducts and hose designed to fit perfectly in the left and right lower vents and our new splitter, adding an even more aggressive look to your 350Z. IMAGES SHOWS OPTIONAL SPLITTER INSTALLED. THE SPLITTER IS NOT INCLUDED WHEN ORDERING THIS PART #. A tip - if you're considering the brake ducts, you'll save 3-4 hours of labor if you do it all at once rather than having to remove/reinstall the fascia later!
Anyone seen the "speed grilles" ?
What do you think of the Front lip splitter?
Old Sep 28, 2004 | 09:14 PM
chazzg's Avatar
chazzg
Default Re: Question on Stillen 2 nose (or similar)
That's not a Radiator, Its an Intercooler. You do not HAVE to put a grille on it, But i think the one For the G35 from Stillen will fit it, and its the same style as the other stillen grilles. I have seen this kit in person and I do not like the Spliter, but if you have aftermarket sideskirts it oul help the over all look of the car.
Attached Thumbnails Question on Stillen 2 nose (or similar)-img_3835-small-.jpg
Old Sep 28, 2004 | 09:18 PM
mgl's Avatar
mgl
everything looks ok, except for that splitter.
i read your other thread, and if you end up getting this stillen bumper, i hope that you are also getting some aftermarket side skirts too.
Old Sep 28, 2004 | 09:41 PM
Moroccan_Mole's Avatar
Moroccan_Mole
i really don't like the look of the stillen bumper, i think im like the only one, haha.
i don't like how the bottom middle section is higher than the sides, the sidemarkers pushed all the way out to the ends, and the way the entire thing just slopes forward ... it sorta reminds me of a catfish.
Old Sep 28, 2004 | 09:58 PM
mgl's Avatar
mgl
now that you said it, i can also see a catfish!
Old Sep 28, 2004 | 11:39 PM
dkny_boi's Avatar
dkny_boi
I knew there was something weird bout the side reflectors but just never really realized it till you mentioned that... the stock position, keeps the whole fender flare in one shape (and lines up w/ the headlites), but where it is on that stillen bumper cuts into the fender flare.
Old Sep 29, 2004 | 01:20 AM
chazzg's Avatar
chazzg
That's not a Fish, This Is a Fish
Attached Thumbnails Question on Stillen 2 nose (or similar)-hopup1_1809_97309020-small-.jpg
Old Sep 29, 2004 | 08:57 AM
ChinaClipper's Avatar
ChinaClipper
i don't like how the bottom middle section is higher than the sides, ...
This design feature exactly mimics the JGTC series 350Z front ends. The raised center lip on the racer is intended to induct air underneath the car where it is used to aid ground effects thru the use of an underbody venturi.
I like it!!!!! The splitter sux though - and the JGTC cars do not have that either!
Old Sep 29, 2004 | 12:21 PM
DrVolkl's Avatar
DrVolkl
Why am I the only one that likes the splitter? Is it really that bad??
Old Sep 29, 2004 | 12:58 PM
mofoz's Avatar
mofoz
i dont like it at all ready. the splitter seals the deal though.
Old Sep 30, 2004 | 03:12 PM
LOU's Avatar
LOU
Anyone have a picture without the splitter?
Old Sep 30, 2004 | 09:43 PM
KrazY-2K's Avatar
KrazY-2K
Kind of OT, but I have NEVER seen the V2 Veilside kit on a Z before. Has anyone ever grown the ***** to uglify their Z with it I wonder...
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
