Halogen and xenon head lamp enclosures
Old Oct 8, 2004 | 02:45 PM
RAR's Avatar
RAR
Default Halogen and xenon head lamp enclosures
I recently had a bit of a run in with a moving van and am in need of a new head lamp. Because my friend was driving the moving van I want to keep the repair costs down for him....
My question: are the head lamp housings (just the plastic casing of the head light, none of the electronics) the same on both the halogen and xenon lights. - I just need the casing, so it would be better for me to order the halogen and just not use the rest of the parts.
I am guessing by the prices that when you order the "LT Headlamp Assy" from the parts catalog you are also getting all the electronics (like the ballast, lamps, etc) with the part....
Halogen Headlamp: $247.87
Xenon Headlamp: $775.92
Any input would be great...
Andrew
Old Oct 8, 2004 | 07:34 PM
thunder0880's Avatar
thunder0880
get the halogen headlamp and just get yourself a aftermarket xenon kit and save some money.
Old Oct 9, 2004 | 06:18 AM
RAR's Avatar
RAR
Its the performance model, so I already have xenon headlamps, do the xenon lamps work in the halogen light casing...
Andrew
Old Oct 9, 2004 | 07:25 AM
thunder0880
oh my bad...yes they will work. I have a base model that came without hids and installed the stock oem hids in it halogen housing. The only think you will need for this will be H7 adapters. You can get them for around $20
Old Oct 9, 2004 | 07:26 AM
ares's Avatar
ares
Veteran
*curious to know the answer as well*
I was under the impression that they werent... but Ive never found a solid answer.
Old Oct 9, 2004 | 07:28 AM
NismoKid's Avatar
NismoKid
I'm pretty sure that price for the HID housing includes new ballast and bulbs, which is what makes it expensive. A halogen light bulb is very inexpensive so the price of the housing is basically the price of the housing + bulb.
The reflector is also different in the two so I'd suggest looking for a used headlight housing from an HID equipped Z. The HID Z uses a different lightbulb size than the Halogen housing so your bulb wouldn't fit without modification.
Old Oct 9, 2004 | 07:34 AM
thunder0880
The HID bulb fits perfectly in the halogen housing, thats why the H7 adapter is needed. It slides over the HID bulb, creating a h7 ring like the halogen bulb for a perfect fit.
Old Oct 9, 2004 | 08:01 AM
RAR's Avatar
RAR
Humm, I may go ahead and get the Xenon housing. If i need an adapter and the reflector is different, then you could most likly tell a differance when looking at the two with the lights on.
I can always sell the ballast and bulb and just use the housing.
Andrew
Old Oct 9, 2004 | 08:19 AM
NismoKid's Avatar
NismoKid
You won't get much if you sell one bulb and one ballast. People can buy aftermarket HIDs (a pair instead of one) for under $400. You wouldn't come close to breaking even if you sell just one bulb and one ballast.
There's a place in New Orleans that sells 350z parts. Their site is www.talrock.com They have HID housings, but I know they get a lot of their parts from Ebay. I'd suggest looking on Ebay first.
Old Oct 9, 2004 | 08:21 AM
NismoKid's Avatar
NismoKid
I dont know if your passenger or driver light was hit, but here's a passenger headlight with the bulb and ballast. http://cgi.ebay.com/ebaymotors/ws/eB...category=36476
Old Oct 9, 2004 | 08:35 AM
RAR's Avatar
RAR
Its the Drivers, its just a mounting point thats broken and some scratches on top.
Thanks for the info, I will look on ebay...
Andrew
Old Oct 9, 2004 | 08:36 AM
thunder0880
ouch
Old Oct 9, 2004 | 09:36 AM
NismoKid's Avatar
NismoKid
It doesn't really look like much damage to me, but there's probably some under the sheet metal. Have you ruled out trying to fix the housing you already have?
Old Oct 9, 2004 | 11:02 AM
RAR's Avatar
RAR
I'm not necessarily worried about fixing the cracked bracket, I just don't want the scrapes at the top of the housing visible... the car was perfect before and I don't want scrapes there after it is fixed.
Andrew
Old Oct 9, 2004 | 12:35 PM
NismoKid's Avatar
NismoKid
Well, I don't know what to say. You could PM richard350z (he's under that username on **********). He crashed his track 350Z and is selling some aftermarket parts from the car. Maybe you could just switch headlight housings since it's only the lens that scratched.
Old Oct 9, 2004 | 01:28 PM
ares's Avatar
ares
Veteran
you might/should be able to buff those scratches out. maybe even get some clear headlight protector things and maybe itll hide it...
one possibility. Id give it a shot before forking over 700 for a new housing anyway.
Pleask
Dec 21, 2021 03:17 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
