best/most preffered trim for 350z??
can some one please break down all the trims of the 350z..and what year in your opinion(s) which is the best including the year (03/04/05). also what each one comes with and what not..and i only see 'performance' somtimes..idk which year that is or what not..if it got discontinued or whatever? also..if planning on getting custom sound system and wheels..thanks.
Originally Posted by kourosH
so you're being sarcastic?
The most popular 350Z is the Touring. Difference between models? Check nissanusa for a detailed listing.
Originally Posted by Bubble
btw, why is this in Feedback, Suggestions & Questions ?
The key to being a helpful forum member is not that you are smart, you just have to look and find stuff. Search is a valuable tool. 2003-2005 350Z below:
BASE MODEL
6-Speed MT Only - $26,269
Longitudinally-Mounted 3.5L 24-Valve DOHC VQ35DE V6 engine producing 280+ horsepower and 260+ lb/ft of torque
Drive-By-Wire Throttle
High Flow Intake System
Continuously Variable Valve Timing (CVTCS)
Micro-Finished Crankshaft and Camshafts
Molybdenum Coated Pistons
Sequential Multi-Port Electronic Fuel Injection
Nissan Direct Ignition System (NDIS)
Transmission
6-speed close-ratio manual transmission
Short Throw Linkage
Drivetrain
Mid Mounted Front Engine/Rear Wheel Drive
52/48 Front/Rear weight balance
Carbon-Fiber Driveshaft
Braking System
Power-Assisted 11.65" Vented Front Disc Brakes & 11.5" Vented Rear Discs
Anti-Lock Braking System (4-wheel ABS) w/ Brake Assist
Electronic Brake Force Distribution (EBD)
Suspension/Chassis
Unibody Construction with Corrosion Resistant High Strength Steel
Lightweight Aluminum Hood
Power-Assisted Engine-Speed-Sensitive Rack-and-Pinion Steering (15.9:1
steering ratio)
4-wheel fully independent Multi-Link suspension
Lightweight Aluminum-Alloy suspension components (suspension arms, entire rear subframe, etc)
Front and Rear Stabilizer Bars
Rear Strut Tower Brace
Aerodynamics
Low coefficient of drag with under car air management system
Flat underbody design with deflector and diffuser plates
Exterior
Aluminum-Look Door Handles
Full Body Color Mirrors and Bumpers
Flush-Mounted Headlights
Dual Outlet Exhaust
High Output, Flush Mounted Halogen Lighting System
17" X 7.5" 7-Spoke Aluminum-Alloy Wheels
P225/50WR17 Front & P235/50WR17 Rear High Performance Michelin Tires
Comfort and Convenience
Tilt Steering Column and Integrated 3-Bay Instrument Gauge Cluster
Automatic Temperature Control System
3-Guage Cluster with Oil Pressure, Voltmeter and Trip Computer
Power Windows, Locks and Mirrors
Remote Keyless Entry System
Variable Intermittent Front Windshield Wipers
Rear Intermittent Wiper
Overhead Sunglasses Storage Compartment
Electric Rear Window Defroster
Leather Steering Wheel & Shifter
Aluminum Interior Accents
6-Way Manual Adjustable Driver’s Seat
160-Watt AM/FM/CD w/6 Speakers
Safety and Security
Dual Stage Supplemental Air Bags
Vehicle Security System
Seat Belts w/Pre-Tensioners & Load Limiters
Nissan Vehicle Immobilizer System
ENTHUSIAST
6-Speed MT - $28,249
5-Speed AT - $29,219
Includes Standard Equipment Plus:
Xenon 4-Bulb High Intensity Discharge Headlights
Traction Control System (TCS)
Viscous Limited Slip Differential (LSD)
Cruise Control
Homelink Universal Transceiver
Aluminum Pedals
Day/Night Automatic Rear View Mirror
Dual Illuminated Vanity Mirrors
Optional:
5-speed Electronically Controlled Automatic Transmission with Manual Shift Mode
PERFORMANCE
6-Speed MT Only - $30,429
Vehicle Dynamic Control (VDC)
18" X 8" 6-Spoke Aluminum-Alloy Wheels
P225/45WR18 Front & P245/45WR18 Rear High Performance Michelin Tires
Tire Air Pressure Monitor
Cruise Control
Aluminum Pedals
TOURING
6-Speed MT - $33,179
5-Speed AT - $31,589
Touring Models w/5-Speed Automatic Transmission:
Bose 7-Speaker 240-watt Audio System w/ In-Dash 6-Disc CD Changer, AM/FM Stereo and Cassette Player
Leather-appointed Seats
Power 4-way Driver’s Seat
Power 2-way Passenger Seat
Heated Seats
Heated Mirrors
Cruise Control
Aluminum Pedals
Touring Models w/6-Speed Manual Transmission Additionally Include:
TRACK MODEL
6-Speed MT Only - $34,079
Brembo Brakes with 4-Piston Front Calipers, 2-Piston Rear Calipers
Front 12.75" Vented Front Discs and 12.67" Vented Rear Discs
18" X 8" 6-Spoke Super Light Forged-Aluminum Alloy Wheels by Rays
"Zero Lift" Package for high speed stability including:
-Rear Drag Reducing Spoiler
-Front Spoiler
Cruise Control
Aluminum Pedals
BASE MODEL
Transmission
Short Throw Linkage
Drivetrain
Braking System
Suspension/Chassis
steering ratio)
Aerodynamics
Exterior
Dual Outlet Exhaust
Safety and Security
ENTHUSIAST
Cruise Control
Aluminum Pedals
Optional:
PERFORMANCE
Cruise Control
Aluminum Pedals
TOURING
Heated Seats
Heated Mirrors
Cruise Control
Aluminum Pedals
TRACK MODEL
-Front Spoiler
Cruise Control
Aluminum Pedals
liqalu04
Jan 2, 2022 12:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
