Plug Reccommendations????
Old Nov 24, 2004 | 02:13 AM
booger's Avatar
booger
No more than one step colder . Some one went 2 steps , and said is was to cold of a plug
Old Nov 24, 2004 | 09:58 AM
etx's Avatar
etx
I think my misfire at idle could be the Copper plugs I'm using, so you may want to stay away from std coppers. I know some new car's like the Mitsu Evo8 have weird coils that don't like copper plugs.
Old Nov 24, 2004 | 10:03 AM
phunk's Avatar
phunk
CJ Motorsports
http://www.cj-motorsports.com/91psi115af.jpg
I pulled that dyno run with about 30,000 miles on the original spark plugs that came in the car when we bought it... i had never even had them out once at that point.
If you do anything... one step colder but same make/model plug. keep the gap at stock too. For up to 400rwhp i would probably just keep totaly stock plugs... but 1 step cooler might be a good idea.
Old Nov 24, 2004 | 10:27 AM
SungNamZ's Avatar
SungNamZ
I know when I installed the Vortech SC they advised to change plugs if you have over 10,000 miles on OEM plugs. As hard as they are to get to, I would change plugs regardless of the miles. I went with NKG Iridium LFR6A1X-11. These are 1 step colder.
Old Nov 24, 2004 | 10:46 AM
etx's Avatar
etx
That's the same exact plug I use. Do you have any misfires or rpm drops at idle? Around ~600 rpm?
Old Nov 24, 2004 | 10:59 AM
G3po's Avatar
G3po
Default plugs
When you say "misfires" , are you getting a CEL?
To clarify, NGK LFR6A1X-11 s are Iridium , you mentioned copper,
So which are you actually having the issue with?
Old Nov 24, 2004 | 07:42 PM
redline tt's Avatar
redline tt
i have 8's but had spome misfire probs i would go w/7
burglapfd
Dec 6, 2020 01:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
35reilly
Sep 28, 2015 07:42 AM
