How to set AUTO mode on E-01?
Old Dec 22, 2004 | 09:07 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default How to set AUTO mode on E-01?
i know i asked this a long time ago..but now that my engine is getting rebuilt..after my car is tuned, i'd like the boost to be set on auto (i understand this is safer to prevent spikes) as opposed to manual.
i've followed the instructions, WOT, blah blah blah...it just kept flashing "auto"
anything i'm totally just missing here???
anything to tell my tuner
(i think he had the same problem as i did)
Old Dec 22, 2004 | 02:25 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
can no one help me??? come on people!
Old Dec 22, 2004 | 02:42 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You need to find an open road and make several..maybe 3-5 3rd gear passes at WOT before the indicator will stop flashing. Be patient...it will work.
Old Dec 22, 2004 | 03:25 PM
westpak's Avatar
westpak
SFZCC
Thanks, I will try again. I did like 3 runs in 3rd and by the time you are done I was like 3 exits away from home, after 5 I will be halfway to Orlando.
Old Dec 22, 2004 | 05:37 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
sharif:
i have tried it , sometimes 10x in a row...to no avail, so, just keep trying? there isn't some step i'm missing?
Old Dec 22, 2004 | 06:03 PM
Sharif@Forged
Forged Performance
Are you holding it WOT as long as possible? And repeating.....starting at the same RPM each time?
Old Dec 22, 2004 | 06:25 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i hold it WOt until i need to chnage gears.... should i let off as i approach higher rmps and keep partial throttle, then repeat w. WOT?
i think i am just dumn and am missing some concept here
Old Dec 22, 2004 | 06:44 PM
Sharif@Forged
Forged Performance
OK...try this.
Find a nice open stretch of road/freeway. Put the car in 3rd gear and start at around 2500rpm and go WOT until 5500pm or so, and then completely release the accelerator or put in the clutch. Now, dont go into the boost again until you find another nice stretch of open road...put it back in 3rd gear...and repeat. 3-4 times shoudl be enough for it learn...but keep trying.
Also, you might want to increase the gain. Some members set the gain at 30 and the start boost inly 1psi before the set boost. Ei....start boost 8psi, and set boost of 9psi.
Sharif@Forged
Forged Performance
do you like my new sig...anyone. ?
Old Dec 22, 2004 | 06:46 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Looks good, like the last one too though.
Old Dec 22, 2004 | 07:06 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
OK...try this.
sharif:
i'll definately try this out mid feb when my engine is rebuilt...what do u think of the tuning issue? the last thread i posted, everyone had a different comment, i know we spoke about this, but do YOU think i should hold off on the injectors and aam fuel system until a few weeks afterthe motor is "broken in " (i know broken in means a different thing based on who u ask)...or, what i would PREFER to do (not if it is going to be detrimental) install the aam fiel system and injectors, and basically everything at once, i want my car back and dont want to have to keep leaving it in a shop for periods of time after it is back from this last 2 month down time rebuild!
so, sharif (and others who havent given me your opinions), what do ya think?
Old Dec 22, 2004 | 07:17 PM
westpak's Avatar
westpak
SFZCC
OK...try this.
Ah, the gain must be th ekey, because I think mine wasn't learning 6 psi as I never could get it to 6 psi, so I will increase the gain and try again.
PS I liked your old sig but this one rocks.
Old Dec 23, 2004 | 07:06 AM
350G's Avatar
350G
I need signatures 101 . . . what program do you all use to make your sigs and what size should the final product be?
G
Old Dec 23, 2004 | 07:32 AM
Brandon@Forged
I use MS Paint, it can be any size (~706x168 is what I use usually).
Old Dec 23, 2004 | 08:53 AM
Sharif@Forged
Forged Performance
Originally posted by 350zDCalb
sharif:
Well, I can only tell you what I plan on doing, since there certainly many different ways to skin a cat.
I am planning on installing everything at once, becuase I am very comfortable with my current state of tune. When I drop the larger injectors in, with the FPR and return system, I will still scale my injectors via emanage...so i wont be running pig rich at idle and cruise. That is a start..and you can certainly break in your motor that way. For the breakin process on the dyno, I might just disconnect the FPR vaccum line for the timing...and run a higher constant pressure to keep A/F safe. I dont wanna go through the hassle of removing the upper and lower manifold again, and all that stuff...so I am doing evrything at once..and breaking in and tuning the car all at once.
Opinions will differ, but that is what I plan on. Idle for 20 mins.....put it on the dyno with progressively stronger pulls and boost. Tuning along the way....and then done. Run crappy oil...change it once after idle it.
I am not planning a long drawn out break-in on my motor.
Old Dec 23, 2004 | 10:29 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
thanks sharif: sounds good, i'm gonna run everything by my shop and now see what THEY jhave to say, but i like your gameplan!
