ordering TT kit tomorow....
Old Jan 4, 2005 | 01:41 PM
GMADD's Avatar
GMADD
Default ordering TT kit tomorow....
Tomorow is the big day !
ordering my Greddy kit for my g35 coupe 5AT.
Need to know if I'm missing something
this is what I'll be ordering so far :
-Greddy tt kit with FMI
-Profec e-01
-greddy turbo timer
-greddy spark plugs
-Apexi bov
-fuel pump
-Greddy front bumper
At the same time I'll be pulling the motor for Pauter rods and Arias pistons 9.0:1
Thanks !
Old Jan 4, 2005 | 01:51 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
gmadd:
i commend u for doing the forged internals at the same time as the tt install ...might want to get the greddy ignition harness to retard timing (around 30 bucks)
look at some of the threads recently up about engine rebuilds:
you'll need:
nissan gasket overhaul kit
arp main and head studs
main and rod bearings (machine shop will order these)
good luck,
TODD
Old Jan 4, 2005 | 01:58 PM
GMADD's Avatar
GMADD
Ooops !
Thanks 350zDCalb , I forgot to add the harness.
I don't want more than 400whp (...yet)
the shop said that he'll put a new gasket
But are the arp main and head studs really needed for 400whp ?
Thanks again !
Tasso-
Old Jan 4, 2005 | 03:43 PM
002-M-P's Avatar
002-M-P
Your building the motor up with better rods and pistons, might as well not make the studs the weak part of your motor.
Old Jan 4, 2005 | 03:59 PM
350G's Avatar
350G
Small investment (main & head studs) for a motor that's about to be overhauled . . . I'd also suggest addressing the fuel system as a whole, rather than just the fuel pump. You could save this for phase 2 if you keep the unit at stock settings. If you pushing more than 6lbs, I'd get the return fuel system since our OEM setups drop pressure like crazy in the high RPMs & moderate boost.
Old Jan 4, 2005 | 04:08 PM
GMADD's Avatar
GMADD
So where can I get the arp main and head studs for a good price ?
I will be leaving it at stock boost for now, but I will get a fuel return line if I up the boost past 6lbs.
Old Jan 4, 2005 | 04:24 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
SGP Racing has ARP main and head studs, heck I believe they are the one's who made them available to the rest of the public.
Old Jan 4, 2005 | 04:30 PM
GMADD's Avatar
GMADD
Cool !
I'll order them tomorow too.
Old Jan 4, 2005 | 06:18 PM
nitrous350's Avatar
nitrous350
I get one in stock for ARP main and head
If you want i can sale .........
and also Your car is 5AT right ?????
get some Trans. Oil Cooler also
Cause MY 350Z 5AT ran with APS kit and my Trans. Oil Tem. is Over 92C
So I get one from Summit...
Old Jan 4, 2005 | 06:28 PM
GMADD's Avatar
GMADD
I have an oil cooler on the way from Edge, I'll be getting TC upgrade also.
please pm me with price
Thanks !
Tasso-
Old Jan 5, 2005 | 06:23 AM
timdawg's Avatar
timdawg
I what oil cooler did you get?
Old Jan 10, 2005 | 05:35 PM
mizzle's Avatar
mizzle
I have a question??? if i went Turbo on a 350z or g35 would nismo internals be ok or would i need to do better? can someone please PM this newbie
Thanks
Mike
Old Jan 11, 2005 | 05:22 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
By NISMO internals do you mean their pistons? If so, they are redabged JE's, and their rods are rebadged Carillo. Before ordering any internals, you should figure out who is going to build the motor for you - use whatever they recommend. Every engine builder has their own favorite brands, and its the type of job you do not want to do more than once
Old Jan 11, 2005 | 01:52 PM
GMADD's Avatar
GMADD
Done !
the order has been placed and should be here in a couple of weeks.
I was thinking of putting in a Nismo low temp thermostat
any comments ?
Thanks !
Tasso-
Old Jan 13, 2005 | 05:22 PM
G3po's Avatar
G3po
Done !
any comments ?
Thanks !
Tasso-
I have read that the low temp thermostat can throw a code on some versions of the ECU.
EnjukuRacing
Sep 30, 2015 06:55 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
