Which F/I kits include a timing solution.
Old Jan 18, 2005 | 10:49 AM
G3po's Avatar
G3po
Default Re: Re: Re: Re: JWT
Originally posted by MIAPLAYA
Ahh ic...Wait arent the APS turobs GT28s?
A custom hybrid of a GT28 yes, if I were to comparo them to 700BBs they would be more like ~800BBs.
Old Jan 18, 2005 | 10:50 AM
MIAPLAYA's Avatar
MIAPLAYA
Default Re: Re: Re: Re: Re: JWT
You wouldn't happen to have a compressor map for those turbos would you? The GT28s?
Old Jan 18, 2005 | 03:39 PM
DaytonaBlue04's Avatar
DaytonaBlue04
I've got a question about the Split Second and J&S timing controls. Do either of these boxes effectively "lock" the timing at the specified amount of retard while the engine is in closed loop? Or can the ECU's closed loop adjustments basically override the timing controller? Im just concerned that even while the timing controller is still retarding at the specified rate that the ECU may advance the timing to an unsafe level under boost, in spite of the timing controller, basically rendering it useless. Im curious because the ECU determines the amount of advance/retard based on conditions other than just MAF voltage and engine RPM. It also takes into account engine temp, ambient air temp, load, throttle position, as well as others. Does the '04 TS reflash address this?
Old Jan 18, 2005 | 04:45 PM
G3po's Avatar
G3po
Default Re: Re: Re: Re: Re: Re: JWT
Nope as far as I know since the compressor/impeller combo is an
APS custom setup, neither GT nor Garett have released maps.
If someone hasem, I'd like to see them though.
Old Jan 18, 2005 | 04:49 PM
G3po's Avatar
G3po
I beleive both J&S and Splitsecond retard timing based upon and integrated MAP sensor input. THe ECU shoudl only operate in closed loop when under vacuum. When under boost, the ECU is open loop and the Piggyback is then enabled to retard timing.
So retard by the PB and ECU in closed loop shoudl be mutually exclusive.
Old Jan 18, 2005 | 05:37 PM
DaytonaBlue04
Ahhh. Seems to make sense.
Old Jan 19, 2005 | 05:19 PM
DaytonaBlue04
Even though I was seroiusly considering a turbo setup, I think Im going to opt for a supercharger due to the ease of installation and tuning. Is there an ideal supercharger setup for 7-8psi of boost? Im looking at both the Vortech and ATI kits and there are some things that dont appeal to me about the two. I dont like the fact that I have to drill a hole in the upper oil pan for the oil return on the Vortech, and Ive heard some bad reviews about the quality of the ATI setup. Even though the Vortech kit is more complete, the method of fuel enrichment seems danger prone. Is there anyway around it, like bigger injectors and an injector controller? Is there ANY kind of oil return setup that wont cause me to have to drill into the upper oil pan? Would it be possible to use the J&S setup on the Vortech instead of the Split Second unit?
I hate to bother you guys with so many questions, maybe I just need to relax and drink a beer or two.
Old Jan 19, 2005 | 06:52 PM
damen's Avatar
damen
Originally posted by nis350ztt
Speaking of the SSR kit, I wish they would answer my question.
what did you ask them? i've called tim richards at SFR.
Old Jan 19, 2005 | 06:55 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
https://my350z.com/forum/showthread....32#post1235532
TrboMike
North East
Sep 28, 2015 06:36 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
