Procharger...whats MAX boost with internal mods???
Old Jan 18, 2005 | 04:04 PM
zcar03's Avatar
zcar03
Default Procharger...whats MAX boost with internal mods???
How much HP and torque can I get out of the stock Z motor by adding a cam,pistons or heads. Are there any packages that can be bolted on. I am going to run a procharger and want to run as much boost as possible, so I def. plan on lowering the CR to maybe 8.5:1.
Old Jan 19, 2005 | 01:48 PM
dynamic6er's Avatar
dynamic6er
24psi is the rating, but that depends on other things. Headers, test pipes, etc.
Old Jan 19, 2005 | 02:53 PM
zcar03's Avatar
zcar03
I have test pipes and plan on getting headers wth the cam and pistons.
Old Jan 19, 2005 | 04:13 PM
ktown z's Avatar
ktown z
Is this 24 lbs for the stock C-2 unit or does the unit have to be rebuilt with different gears?
Old Jan 23, 2005 | 09:05 PM
dynamic6er's Avatar
dynamic6er
24lbs on the stock unit, but thats a realative number to the VE of the engine.
In other words, headers, cams, and other engine mods will lower the amount of boost that is seen in the manifold, but increase the overall amount of air forced into the engine.
Old May 14, 2006 | 01:55 PM
trefling's Avatar
trefling
Sorry but from experience I don't think anyone will ever see 18psi of boost or more unless your running no intercooler in which case the heat will blow your motor from detonation
Old May 14, 2006 | 02:05 PM
sentry65's Avatar
sentry65
the burninator
psi does not equal power
power is power
try to use mods that make power. Otherwise bone stock will give you the highest potential for high psi numbers and low power
Old May 15, 2006 | 04:11 AM
trefling's Avatar
trefling
Very true especially when it comes to superchargers. Turbo's make big claims too but generally seem to live up to them a little better
Old May 15, 2006 | 04:18 AM
trefling's Avatar
trefling
Your procharger won't flow enough air to make use of a very low compression ratio of 8.5:1 and work better with a litte higher compression ratio. If you put on the big 44 tooth cog pulley your blower will flex forward break the larger belt. Call CPRacing if you want more info on this, they have witnessed it first hand. But the good news is that if you can take care of the torque flexing issue you'll have 450-500rwhp with zero lag which makes for a very fun driving experience. I've taken my Z on roadcoarse a few times and I perfer superchargers for power in turns and quick throttle response. Turbo's make bigger power but unless you have ultimate throttle control the power easily gets away from you very fast in cornering. With a supercharger you always know what to expect
Old May 15, 2006 | 08:02 AM
plumpzz's Avatar
plumpzz
Wouldnt you also need to build the bottom end if your going for tha tmuch power? The stock heads and cams flow good to about 500whp i hear.
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
