E-01 Manual mode help
Old Feb 4, 2005 | 09:03 AM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default E-01 Manual mode help
I need help with my manual mode settings. Does anyone know what I should enter to get it at stock boost or near stock boost. I have been getting spikes on auto mode and would like to try using manual mode.
Old Feb 4, 2005 | 09:28 AM
westpak's Avatar
westpak
SFZCC
Put SET=0 that is stock boost.
If you still get a small spike lower the GAIN number but keep the SET at 0.
Also set you START at 3 or less.
Then record a runn and see if boost holds steady, if not then you have to play with the RPM Offset numbers.
Old Feb 4, 2005 | 10:48 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Boost controllers are very poor at getting stock or near stock boost levels. They arent designed to really do that.
Just turn it to the off position. You should have pretty steady boost with just the wastegates...as long as the lines are installed correctly.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
aarrgghh
May 1, 2022 11:04 AM
NiLL
Nov 29, 2021 02:26 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
