TS and 100% throttle
Old Feb 28, 2005 | 01:36 PM
booger's Avatar
booger
Default TS and 100% throttle
TS flashed my ECU for...rev limiter...speed limiter...thottle body 100% open . The other day I had the OBDII hooked up and it only showed 85% open at WOT . Has any one confirmed with a OBDII or another scanner that thier throttle body was at 100% open at WOT ?
Thanks Bill
Old Feb 28, 2005 | 02:25 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
OBDII is inaccurate as far as our cars are concerned. In fact, 85-88% on an obd2 scanner IS in fact 100% for us...
Old Feb 28, 2005 | 02:33 PM
booger's Avatar
booger
OK cool...was just about going to send the ECU back to TS
Thanks...Bill
Old Feb 28, 2005 | 05:19 PM
SungNamZ's Avatar
SungNamZ
Bill, I had my ECU 'limited flashed' by TS. Just did some dyno pulls and data logging using Zeitronics. TPS was displayed on the graph at 99%. Not sure if it will even show 100%.
Old Feb 28, 2005 | 05:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I think it should be showing much more tha 85%...very close to 100%. The sampling rate on most of the BDII softwares is pretty slow..but something like TPS should be very close.
I run an OBDII scanner....very accurate and fast sampling rates.
Old Feb 28, 2005 | 06:29 PM
booger's Avatar
booger
I'll see if I can adjust the sample rate on my OBDII and try iy again
thanks guys Bill
Old Mar 1, 2005 | 03:37 AM
zillinois's Avatar
zillinois
I have the TS flash as well, and that logger showed %85 percent for me as well.
Old Mar 1, 2005 | 03:48 AM
zbicklin's Avatar
zbicklin
Ditto... I had my ECU reflashed by AAM twice. The second was their "F/I reflash" which I know pulls timing. I noticed that I only record about 83% at WOT on my Zeitronix. It may be for 'safety but I sure hate leaving HP's on the table. -Steve
Old Mar 1, 2005 | 04:18 AM
Sharif@Forged
Forged Performance
Can someone with a TS reflash confirm what their TPS level is? Something doesnt sound right here.
Old Mar 1, 2005 | 05:17 AM
SungNamZ's Avatar
SungNamZ
I have the TS "Limited Flash". Data logged six dyno pulls on Thursday with Zeitronix. At WOT, TPS ranged from 98% to 99%.
Old Mar 1, 2005 | 06:49 AM
booger's Avatar
booger
I bought the OBD from Zillinois . He got what I got ...85% . SungNamZ gets 98% with Zietronix
zBicklin get 83% with Zietronix
Old Mar 1, 2005 | 11:03 AM
JonathanG35's Avatar
JonathanG35
getting on this thread since i just sent my ecu to ts.
Old Mar 1, 2005 | 08:09 PM
DIGItonium's Avatar
DIGItonium
So if I have my TS ECU flash... any adverse effects once I join the FI club? I'd really like the throttle limit fix... not sure what else is beneficial prior to FI. Any suggestions would be nice..... to flash, or not to flash!?
Old Mar 2, 2005 | 03:46 PM
booger's Avatar
booger
Ok..I recalibrated my OBDII and Im still only getting 85% TPS . Im going to wait till I get my Zeitronix hook up and see what it reads. If it reads 85% too , Im going to send in the ECU to TS and have them check it . I need to know if the throttle body is opening up all the way .
Old Mar 2, 2005 | 10:33 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Subscribing, I was also planning on getting an L-Spec reflash.
Old Mar 3, 2005 | 05:08 AM
SungNamZ's Avatar
SungNamZ
booger, if I recall, didn't you have to return your ECU to TS to have your ECU reflashed. You once had the "full" flash and Vortech SC was looking for OEM ECU with exception of rev limit, throttle and speed limit. Maybe, just maybe, TS didn't get it right.
I did the "Limited" flash and showing throttle at 99%. Trying to figure out how CaneZMD is showing 100% on his Zeitronix data logging.
Old Mar 3, 2005 | 10:26 AM
booger's Avatar
booger
I had it flashed before the Vortech install . Sent it back to have stock fuel trim put back in . But told them to leave the rest . The Zeitronix should be here soon and I'll check it then . Its going back to TS if it doesnt show close to 100%
Old Mar 3, 2005 | 10:37 AM
SungNamZ's Avatar
SungNamZ
Sounds like they might have reset everything on your ECU back to OEM. With that "new" engine, you probably have not been able to see if you are hitting the "rev limit".
Old Mar 3, 2005 | 10:48 AM
booger's Avatar
booger
Yea...Rev limit is 7,200rpm...no speed limit...I had them reflash last year . I never had any way to check it till now
Old Mar 3, 2005 | 12:40 PM
SungNamZ's Avatar
SungNamZ
When you get your Zeitronix back it will be easy see. My Rev Limit is also at 7200, with no speed limit and 100% Throttle. I will watch for your future posts or send me a PM.
