Are stock rods suitable for FI VQ engines?
Old Mar 12, 2005 | 05:48 PM
  #161
jeffw's Avatar
jeffw
Seems like there is a fair bit of disagreement with Peter on this issue. What I'm curious about is if there is actually a bearing problem?
From what I understand, all the rebuilds are using stock bearings (due to lack of alternatives) and shooting for largish clearances. Aside from the benefits of large clearances, there is also the fact that the big end bearing housing will be stiffer due to forged rods (less potential bearing deflection). Is it reasonable to expect the bearings to hold up well in a built engine even though they don't have any more surface area and are of stock material and thickness?
BTW, has anyone tracked the actual number of blown engines posted here where there were no signs of detonation? From my foggy memory, it seems most had melted pistons and/or chunks missing from the ring lands to go along with any additional engine damage.
Thanks
Jeff
Old Mar 13, 2005 | 09:39 AM
  #162
thawk408's Avatar
thawk408
We all know that the supra factory rods are pretty damn strong. I have heard that they are not forged, but I have never personally seen one. Does anyone have a picture of a supra factory rod to compare to the Z rod?
Old Mar 13, 2005 | 12:11 PM
  #163
redline350ZZ's Avatar
redline350ZZ
subscrib.......
holding off F/I for one more year......just when my 36,000 miles arrive
Old Mar 13, 2005 | 03:37 PM
  #164
APS's Avatar
APS
Jeff that's fine, it would be a very boring world if everyone agreed on every technical issue.
I'm still very confident that a continous reliable supply of engine oil under high load engine conditions will pay big dividends, I'd be willing to bet that nearly all VQ turbocharged engines will be running a hi volime air cooled oil pan with improved baffling around the oil pickup over the next 12 months, let's wait and see, I'm sure time will prove my belief to be correct.
Thanks
Peter
Old Mar 13, 2005 | 04:11 PM
  #165
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Below...
stock 2JZGTE connecting rod...
Below that...
stock 350Z rod and piston on top...Arias piston and Pauter rod on bottom...
Attached Thumbnails Are stock rods suitable for FI VQ engines?-arias-pistons-and-pauter-rods-compared-to-stock-rods-and-pistons.jpg
Old Mar 13, 2005 | 07:08 PM
  #166
thawk408's Avatar
thawk408
Originally Posted by nis350ztt
Below...
Below that...
WOW! Those supra rods are crazy.
Old Mar 14, 2005 | 12:25 AM
  #167
APS's Avatar
APS
Below...
Below that...
Are you sure that a stock 2JZGTE rod?
Looks more like an after market con rod to me, please confirm.
Peter
Old Mar 14, 2005 | 06:18 AM
  #168
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Below...
i am 90% sure this is not a stock Supra rod. They have a rougher finish to them.
This looks very much like a typical H-beam aftermarket rod, like Eagle, or Carillo.
Maybe I am wrong???
Old Mar 14, 2005 | 08:56 AM
  #169
azrael's Avatar
azrael
Peter
A quick google image search yields this:
I find this much more likely to be a picture of a stock Supra rod. They look beefier than the stock VQ35DE rods, but not nearly as thick as an aftermarket forged H-beam rod. With that said, we know that VQ35DE rods are forged, but I am not aware of the composition of a stock 2JZ-GTE rod. Does anyone else know? I know there are a few guys here who are current or former MKIV Supra owners.
Matt
Old Mar 14, 2005 | 09:27 AM
  #170
thawk408's Avatar
thawk408
Those look very close to the Z rods.
Old Mar 14, 2005 | 10:33 AM
  #171
Brandon@Forged
Hmm, must not be the stock 2JZGTE rod...I asked an mk4 supra owner if he had a pic and he sent me one that he said he didn't think it was stock and then sent me a second one (the one I posted) that he said he was pretty sure it was stock, it said it was stock (maybe it was on a forum or something)...I was going to Yahoo!™ (lol) it today and see if I could find something. My mistake guys...
Old Mar 14, 2005 | 10:58 AM
  #172
APS's Avatar
APS
Matt
Both the Supra and VQ stock con rods are forged though the stock Supra rod does look bigger/stronger than the stock VQ con rod imho, that said I'm sure that the stock VQ rod is stronger than what many believe.
Peter
Old Mar 14, 2005 | 11:24 AM
  #173
tinman's Avatar
tinman
the 1st pic is H-beam Carrillo rod.
this picture of mine confirms that.
Old Mar 14, 2005 | 12:43 PM
  #174
JonathanG35's Avatar
JonathanG35
Originally Posted by JonathanG35
Here is what may be a stupid idea:
The amount of power the factory rods can handle has always been a matter of conjecture - would it be possible to take a rod and put it in some type of hydraulic press and apply pressure on it until it breaks and translate that pressure to a relative hp or torque value? I realize you may have to sample several rods to get a base line value. With all the people getting forged internals there may be some extra rods around that could be donors.
i posted this idea on page 6 or so and it kinda died off so I will put it a different way:
Does anyone have any ideas as to how we may determine the tolerable hp levels for the rods in and of themselves?
We need to try to reduce the variability in the equation of building hp with the VQ.
Old Mar 14, 2005 | 12:47 PM
  #175
Brandon@Forged
Jonathan has a good idea...
The only other way would be to take it to a tuner that we know KNOWS how to tune and keep raising the boost and adjusting and see where they snap.
The hydraulic press sounds like a great idea though, we probably have 4 or 5 rods from every buildup and ~5 buildups, that's plenty.
Old Mar 14, 2005 | 12:52 PM
  #176
jeffw's Avatar
jeffw
This PDF has some good stuff in it about testing rods.
http://www.autosteel.org/pdfs/gdis_2004_fatemi.pdf
I think the key is that you don't want to just compress the rod till it breaks. You really want to do some sort of cyclical stressing of the rod.
Jeff
Old Mar 14, 2005 | 04:58 PM
  #177
JonathanG35
Jeff
I wonder how much it would cost to have that type of testing done? I would chip in.
Than pdf was great info - thanks
Old Mar 15, 2005 | 07:17 AM
  #178
Sharif@Forged
Forged Performance
Peter, I was re-assembling my motor and oil pans last night, I can tell you with absolute 100% certainty, that there is no way for the pickup to be starved of oil under any conditions....unless the car had about 1-2qt of oil in it total.
If you take a look at the stock oil pan, it is very shallow, and holds maybe 1qt of oil at the most. The rest of the oil is in the upper oil pan. Now, the pickup sets very low. It actually sits about halfway into the LOWER oil pan. So if you picture that in your head, there would have to be close to 1qt of total oil in the car for that pickup to be starved. even under acceleration or side to side cornering, there is no way that 4 qts of oil would evacuate from the area that the pickup sits in.
That said, I still recommend the APS oil pan, primarily for the increased oil capacity, and better cooling ability. I would highly recommend it as a precaution for anyone running F/I on their cars.
But the fact is, there is no oil starvation issue, as it relates to the oil pan and pickup location. If there is an issue with oil starvation, it has nothing to do with the oil pan and pickup location.
Hope this helps.
Sharif
Old Mar 15, 2005 | 07:23 AM
  #179
MIAPLAYA's Avatar
MIAPLAYA
Hope this helps.
Sharif
Finally someone who agrees with me and actually has looked at it and can tell from experience. I too looked at it and came to the conclusion there was no way...
Old Mar 15, 2005 | 09:36 PM
  #180
APS's Avatar
APS
Sharif thanks for your input though I'm not sure I totally agree with your thoughts, there is no baffling around the pick up so what do you think happens to the oil when you accelerate the car quickly?
I have over the last 2 weeks (I have a engine block and oil pan sitting on my work bench) and I still think it's very possible for the oil to run away from the main oil pickup, just my opinion.
Sharif I think you are overlooking the amount of oil that is circulating the engine any any given time, there's not always 4 quarts of oil in the lower pan. I suspect that if the engine oil level is low and under quick acceleration that it's entirely possible that the engine may starve for oil.
I also believe a hi volume well baffled oil pan is also a wise choice and I believe that you will find that in a very short time that most if not all high powered FI VQ engines will have a larger air cooled oil pan with additional baffling around the oil pickup to ensure a continous reliable supply of engine oil.
Thanks
Peter
