got my new rods in today
Old Mar 5, 2005 | 01:12 PM
burnt350z's Avatar
burnt350z
Default got my new rods in today
i took my engine apart knowing that i was going to get my rods and pistons in i bought crower billet rods and there is no little hole for the oil to run through is this normal? and what should i do?
Old Mar 5, 2005 | 04:12 PM
g356gear's Avatar
g356gear
Not to worry....Pauters are the same if I remember corrrectly.
Old Mar 5, 2005 | 04:18 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The Pauter rods have one oil hole drilled into the small end. Some rods have that hole...and some dont. Thats why I really like the Pauter.
Also note, the Crower rods are not correctly designed for the VQ. So you have to have the machine shop notch the block for them to clear. I think some shops can also notch the rods.
Either way, they need to be modified in order to work without hitting the block.
Old Mar 5, 2005 | 08:56 PM
burnt350z's Avatar
burnt350z
hey when i got the rods i called the place up and asked them if they were a direct bolt on and they said yes. and should i get the holes drilled for the oil or not? thanks
Old Mar 5, 2005 | 09:03 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
burnt350z..why do you keep posting the same post over and over?
Old Mar 5, 2005 | 09:09 PM
burnt350z's Avatar
burnt350z
sorry im not meaning to i pressed back and my comp froze
Old Mar 5, 2005 | 10:01 PM
Brandon@Forged
Ahh, I figured it was just the computer that messed up. It's fine.
Old Mar 5, 2005 | 10:43 PM
Sharif@Forged
Forged Performance
Your shop may not have known about this. I myself didnt learn about it until Kyle at SGP Racing mentioned it to me, and then one other forum member did a home install and found out himself as well.
Regarding the oil hole, I am not 100%, since I dont know when exactly the hole is drilled in the production process. I would check with your machine shop.
BTW, the Crower rods are excellent rods...so no worries...just get the block notched and you'll be fine. Your machine shop can do all of this for you.
Old Mar 5, 2005 | 11:31 PM
burnt350z's Avatar
burnt350z
thanks for your help gq_626 and it nice to know now then finding out for myself
Rev_Night
Nov 7, 2020 06:00 PM
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
