Not a bad day on the dyno
Old Mar 18, 2005 | 09:29 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Default Not a bad day on the dyno
Built G35 with Greddy TT Kit and HKS V-pro @ 18 Lbs of boost
Old Mar 18, 2005 | 09:33 AM
meatbag's Avatar
meatbag
Nice numbers, hopefully my car will be making that kind of power soon.
Bryan
Old Mar 18, 2005 | 09:44 AM
kopo's Avatar
kopo
good lord, not bad at all
Old Mar 18, 2005 | 10:01 AM
t32gzz's Avatar
t32gzz
Kyle, congrats on the numbers. Did you do this on pump gas or what octane were you using? Also, did this car have cams and headwork, or just pistons and rods? I am seriously considering bringing you the car back to tune.
Old Mar 18, 2005 | 10:07 AM
ImportPartsPro
Tim,
18 Lbs on 93 octane pump gas.
CP Pistons, Pauter Rods, JWT Cams, and headwork.
and so people don't get confused that is:
560 Rwhp and 629 Ft/Lbs
Old Mar 18, 2005 | 10:11 AM
mojo powered's Avatar
mojo powered
WOAW congrats...
I guess the VQ keeps proving to be a very torquey engine.. why such a big difference between the torque and hp? Not that I would mind it! That thing can haul 2 boats attached to a mobile home lol. GOOD JOB !!
Old Mar 18, 2005 | 11:27 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Originally Posted by Kyle(Houston)
Tim,
That is GREAT! I'd love to be making that much TQ over HP. He needs to go run it at the track and see what it will do! I bet that TQ feels great when launching.
Old Mar 18, 2005 | 11:41 AM
bwzabodyn's Avatar
bwzabodyn
Kyle, you will definitely be enlisted to do my built engine project whenever I'm ready to take the plunge next year...
What is a rough estimate of the total costs involved to get to ~500hp/tq? (including new block) $12k? $15k?
Old Mar 18, 2005 | 12:26 PM
fernandito7's Avatar
fernandito7
wow those are some insane numbers. congrats. I would also like to know how muich this would cost to get it done and how much time it would take to get itdone
Old Mar 18, 2005 | 01:12 PM
barthelb's Avatar
barthelb
Master
Wow I'd like to know how he's gonna hook up. Can you say 5th gear!
I have a question, on the graph it shows flywheel. Then a lil later Kyle posted saying that it was RW numbers. Is it really rear wheel numbers. That's just crazy either way but even more if it is.
Old Mar 18, 2005 | 03:37 PM
t32gzz's Avatar
t32gzz
Fernandito, you can find the price on SGP's website under engine pakages. They have a bunch of packages and they also allow custom.
Kyle, insane, yep, you are definitely tuning her too. I will bring her back a couple of weeks after I pick her up.
Old Mar 18, 2005 | 03:44 PM
VR3's Avatar
VR3
Insane!
Old Mar 18, 2005 | 04:44 PM
drsifu's Avatar
drsifu
congrats....but like a previous poster said, the chart shows torque at the flywheel and then you say at the rear wheels. which is correct?
also, looks like you ran on a dynapack. what HP/TQ would you equate if the car was run on a loaded dyno?
Old Mar 18, 2005 | 04:59 PM
GMADD's Avatar
GMADD
NICE !
Old Mar 18, 2005 | 05:56 PM
Gman2004's Avatar
Gman2004
THAT'S DISGUSTING! I want one!
Old Mar 18, 2005 | 06:03 PM
Gman2004's Avatar
Gman2004
Tim,
Kyle,
Which motor would this be? Ugraded block 1, 2, or 3? What does the + $2000 core mean?
Upgraded Long Block #1: $5900 + $2000 Core
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Shot peened stock rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
5 angle valve job
Valve Stem Heights set
Cold Clearance set
*JWT Upgraded Cams
*JWT HD Valve Springs
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Upgraded Long Block #2: $6000 + $2000 Core
Block redecked
Crank balanced
*Pauter Rods
ARP Rod Bolts
*ARP Main Studs
*ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Upgraded Long Block #3: $7500 + $2000 Core
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
*Ceramic coating on Pistons
ARP Main Studs
ARP Head Studs
Heads redecked
*JWT Upgraded Cams
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Old Mar 18, 2005 | 06:10 PM
Enron Exec's Avatar
Enron Exec
Very nice work Kyle!!!
Old Mar 18, 2005 | 10:52 PM
002-M-P's Avatar
002-M-P
Great numbers Kyle. Amazing the torque being so much higher than the horsepower.
Old Mar 18, 2005 | 11:14 PM
002-M-P's Avatar
002-M-P
Just looked at the graph again and had a question. Why did you only run it to 6000 rpm?
Old Mar 19, 2005 | 05:13 AM
ImportPartsPro
The dynopack only reads RWHP and RWTQ. There is no way to properly calculate actual Flywheel HP and TQ. I am not sure why Dynopack decided to label the TQ reading with "flywheel" but I can assure you it is the RWTQ.
For people that want estimates on engine builds and tuning involved in getting this type of power please email me at sales@sgpracing.com and I will be happy to give you estimates on what is involved.
