Oil Temp/fuel pressure
Old Mar 19, 2005 | 11:20 AM
Phaneom's Avatar
Phaneom
Default Oil Temp/fuel pressure
Going to be doing my Vortech install soon and I was wondering where the best place to install the oil temp and fuel pressure sensors. Can the oil temp sensor be tapped right into the oil pan? As for the fuel pressure. I guessing it can be TEE'ed in between the fuel rail and the FMU?
please tell my if I'm wrong, or if there is a better way to do this.
Thank you for the help
Old Mar 19, 2005 | 11:23 AM
booger's Avatar
booger
Ive never done a oil preasure gauge , but it will not work tapping the oil pan . There is no preasure in the pan
Old Mar 19, 2005 | 11:25 AM
Phaneom's Avatar
Phaneom
Oil temp not oil pressure
Old Mar 19, 2005 | 11:36 AM
booger's Avatar
booger
ooops sorry..didnt read it good enough
Old Mar 19, 2005 | 02:57 PM
lovetoclown's Avatar
lovetoclown
I installed an oil temp sensor. For me, I installed it in the JWT oil pan spacer. So it was VERy simple, and I have an extra quart of oil.
Old Mar 19, 2005 | 04:34 PM
gersteinp's Avatar
gersteinp
Depending on the kind of fuel pressure sender--it mounts on the fuel rail and either sends an electrical signal (better and safer), or an actual small fuel line to the gauge (crazy).
Old Mar 19, 2005 | 08:28 PM
lovetoclown
If you use the fuel line straight to the gauge, then yes it's crazy. That is why there is a peice that goes from the gauge to the engine bay and is fill with radiator fluid. That way if the line snaps, no gas ends up on you.
Old Mar 20, 2005 | 05:17 AM
Phaneom's Avatar
Phaneom
Its an Autometer Sport-comp full sweep fuel pressure gauge (Electric) the oil pressure is also a Autometer Sport-comp electric. Yeah I figured brining fuel into the cabin of the car would not be such a good idea.
Old Mar 20, 2005 | 05:24 AM
Phaneom's Avatar
Phaneom
You wouldn't happen to have a picture of where/how you mounted yours? Just want to make sure I do it right, and a picture can tell a 1000 words
When I do my install I'm gonna take pictures of everything this way we all can learn from it.
Old Mar 20, 2005 | 07:20 AM
MIAPLAYA's Avatar
MIAPLAYA
For my fuel pressure sensor I bought the AAM fuel pressure mounting block adaptor. I also have Autometer full sweep electric gauges. Mine are the CF series. For the oil temp use a + fitting on the stock oil pressure sender which is where you will be connecting the oil feed to the Supercharger anyways.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
