?'s on profec e-01 and e-manage
Old Mar 20, 2005 | 06:11 PM
ktown z's Avatar
ktown z
Default ?'s on profec e-01 and e-manage
I currently have my ecu reflashed (Technosquare) for PE 380cc injectors and the procharger. I am switching from the procharger to GReddy twins and plan on using the e-manage and profec e- 01 boost controller. Do I need to reflash my ecu to stock to use the emanage for A/F controll, or can I use the current reflash and tune from there? Also what options of data can the e-01 display ie.. boost, rpm, a/f ratio, and what optional harnesses do I need to display these options (especially boost and rpm)? Thanks
Old Mar 20, 2005 | 07:04 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You could go either way in your situation. The good thing is your injectors are already scaled for 380cc's, so the emange will only have to scale from 380 to 440. The TS base tune probably wont hurt you, but you will definately need to retune with the eMange. THe only issue is that if the TS Reflash is running too rich, then you have no way to reduce fuel...unless you use a MAF correction, which is not advisable due to unwanted timing advance that will result.
So, if money was no object, I would change your Reflash to an OEM map, but then have TS keep the L-Spec upgrades, and have TS reflash your ECU for 440cc injectors.
Regarding your second question, all you need is the e-01 input signal harness, and you will be able to view and log additional inputs..like an AF sensor, or EGT.
Old Mar 23, 2005 | 06:32 PM
ktown z's Avatar
ktown z
Thanks, I was trying to save the 150.00 TS wanted to change the ECU back to stock form. I don't want to run just the ECU reflashed to the GReddy twins because I believe tuning with the E-manage will offer greater gains and I can control the A/F easier. Do you think it will be more benificial to get the ecu flashed to the L-spec. What is included in the L-spec reflash (speed limit removed, red line moved to 7200, throttle body at 100%) what else and what about the timing?
Old Mar 23, 2005 | 07:30 PM
Sharif@Forged
Forged Performance
L-Spec includes throttle body 100% fix, speed limit eliminator, and raising the rev limit (if you desire).
Timing can be controlled via eManage.
Old Mar 24, 2005 | 06:52 AM
Gman2004's Avatar
Gman2004
Sharif,
did you remove the rev limit on your Z?
bcoffee20
Nov 19, 2015 06:39 PM
aalzuhair
Middle East
Sep 15, 2004 09:46 AM
greddyZ
May 24, 2004 06:47 PM
jimster716
May 18, 2003 09:02 PM
