Reflash, emanage, or both?
Old Mar 22, 2005 | 04:24 PM
Badmonkey's Avatar
Badmonkey
Default Reflash, emanage, or both?
Ok, here is my question. I am having my Procharger installed as we speak. Am I ok with the ATI FMU? I am considering the TS reflash, I talked with them today and they said that if I get the reflash, I can do away with the FMU. If I get the reflash should I buy the emanage to fine tuneing? I am also thinking about the 380cc injectors. I just want a reliable daily driver thats kicks a$$.
Old Mar 23, 2005 | 07:35 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
TS is right...the first thing to do is ditch the entire FMU and fuel system that comes with the ATI.
TS can get you close, but an eManage would be better for tuning, IMHO. You should also get a return fuel system, so you will have stable, and then rising fuel pressure as boost increases, which is precisely the way you want it.
You might consider doing the TS limited spec flash, and then have them scale the ECU for the larger 440cc injectors you should be running for this setup. Then you can tune the rest of the way with the eManage.
Old Mar 23, 2005 | 01:21 PM
Badmonkey's Avatar
Badmonkey
Will my stock injectors be fine for normal daily driving? If I do go with larger ones are the 380cc's too small? I see that a member has the 380cc's for sale for $475, seems like a good price.
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
Sharif@Forged
Jul 15, 2004 12:26 AM
ACP
Jun 28, 2004 06:51 AM
derek_i
May 9, 2004 08:27 AM
slay2k
Apr 13, 2004 06:15 PM
