Going Greddy TT...recommendations please
Old Apr 4, 2005 | 10:32 AM
  #41
Naveen's Avatar
Naveen
Originally Posted by Gman2004
just by chance, do you know how much a new motor costs? future thought?
Old Apr 4, 2005 | 10:37 AM
  #42
Gman2004's Avatar
Gman2004
I am going with one of these for my rebuild. I have not decided yet...thinking about the $6000 but what's another $1500 when I have spent so much already. Might as well just go all the *** out.
Upgraded Long Block #2: $6000 + $2000 Core
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
*Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*ARP Main Studs
*ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Upgraded Long Block #3: $7500 + $2000 Core
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
*Ceramic coating on Pistons
ARP Main Studs
ARP Head Studs
Heads redecked
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Old Apr 15, 2005 | 05:59 PM
  #43
Naveen's Avatar
Naveen
also, can you buy new motors straight from nissan?
Old Apr 17, 2005 | 06:10 AM
  #44
Gman2004's Avatar
Gman2004
sure you can, but why would you buy a stock motor if you blew up the one you already had. The way I see someone doing this is if they are going back to n/a.
sales@czp
Sep 23, 2019 03:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
