how much does it cost to build up z motor?
Old Apr 12, 2005 | 12:08 PM
dapolishdude's Avatar
dapolishdude
Default how much does it cost to build up z motor?
i come from the world of supras where the stock block is good for 900rwhp so i never really had to worry about buidling up the motor, but on Zs, i see thats not the same thing, how much does it cost to build up a Z motor so it can take like 15-20lbs of boost?
Old Apr 12, 2005 | 01:17 PM
westpak's Avatar
westpak
SFZCC
Search is your friend.
Old Apr 12, 2005 | 01:23 PM
Lorca@Z1's Avatar
Lorca@Z1
Check SGP's website SGP for a general idea.
g356gear's Avatar
g356gear
https://my350z.com/forum/fi-faq-s/112693-how-to-do-twins-right-the-first-time.html
This thread has some budgetary numbers I believe. About $4000 in parts plus labour and machining costs for a basic build with no headwork.
Old Apr 12, 2005 | 02:03 PM
Gman2004's Avatar
Gman2004
These are the different packages SGP offers.
We are offering rebuilt short and long blocks. These will come with a 1 year warranty against "DEFECTS" or for $300 for the short block and $500 for the long block a 3 year warranty. Every spec for even the basic rebuilt shortblocks will be the same as we use in our race engines. With SGP oil control specs, Clearances, and ring gaps, you can feel secure that you will have the best rebuilt block in the country. We are also one of the very few companies that use a torque plate to bore and hone the cylinders for a truer assembled bore. Here are some of the packages available:
Basic short block: $2700 + $1000 core
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
Shot peened stock rods
ARP Rod Studs
New Rod and Main bearings w/ceramic coating
CP Pistons .020 over(8.5:1 or 11.5:1)
Upgraded Shortblock: $3600 + $1000 core
Block redecked
Crank balanced
New Main and Rod bearings w/ceramic coating
*Pauter Rods
ARP Rod Bolts
Ultimate short block: $3900 + $1000 core
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
*Ceramic coating on Pistons
*ARP Main Studs
Basic Long Block: $4500 + $2000 core
Block redecked
Crank balanced
ARP Rod Studs
New bearing and rings
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
3 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Upgraded Long Block #1: $5900 + $2000 Core
Block redecked
Crank balanced
ARP Rod Bolts
Heads redecked
5 angle valve job
Cold Clearance set
*JWT Upgraded Cams
*JWT HD Valve Springs
New Nissan Oil Pump
Upgraded Long Block #2: $6000 + $2000 Core
Block redecked
Crank balanced
*Pauter Rods
ARP Rod Bolts
*ARP Main Studs
*ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Upgraded Long Block #3: $7500 + $2000 Core
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
*JWT Upgraded Cams
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Old Apr 12, 2005 | 06:19 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Also check out Going Deep's built motor thread...it walks you through the needed elements, and it's a good starting point for you. It's pinned in this forum.
Old Apr 12, 2005 | 06:37 PM
xxlbeerZ's Avatar
xxlbeerZ
So is this the best build up for a little bit of everything? I mean you don't REALLY need a five angle valve job, and you can always add cams and stuff later right?
Block redecked
Crank balanced
ARP Rod Studs
Heads redecked
3 angle valve job
Cold Clearance set
New Nissan Oil Pump
Old Apr 12, 2005 | 06:43 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
It depends on how built you want it.
Talking near everything?
Probably around 10k in parts.
Old Apr 12, 2005 | 06:55 PM
Gman2004's Avatar
Gman2004
True, but you will pay for labor twice. If you plan on added these things if you have the money you might as well do it at the same time and save on the labor. If not it will cost you more in the long run.
Old Apr 12, 2005 | 08:03 PM
002-M-P's Avatar
002-M-P
Block redecked
Crank balanced
ARP Rod Studs
Heads redecked
3 angle valve job
Cold Clearance set
New Nissan Oil Pump
I would not choose this one. It retains the stock rods that are just shot peened. I would accept nothing except a nice set of forged rods such as Pauter rods. Remember, the rods are what go in or turbo'd motors.
Old Apr 12, 2005 | 08:35 PM
xxlbeerZ's Avatar
xxlbeerZ
Ah, I didn't catch that. I guess the next one up that has upgraded rods is the best one then. ($6000+$2000core)
Old Apr 13, 2005 | 07:07 AM
Z33Concept's Avatar
Z33Concept
Anywhere from 15-20 Gs
Old Apr 13, 2005 | 07:21 AM
ZRAYGO's Avatar
ZRAYGO
for everything that I have put into my car (parts and tuning and retuning....and retuning....oh yea....and retuning) it cost about.....10k-12k
Old Apr 13, 2005 | 07:41 AM
thawk408's Avatar
thawk408
I think that the best price is the:
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
*ARP Main Studs
Just add some ARP Head Studs and this seems like a strong block that will give you more power then you would need.
Old Apr 13, 2005 | 07:52 AM
Gman2004's Avatar
Gman2004
How much power would the ultimate short block be good for?
Old Apr 13, 2005 | 08:30 AM
Eddie1979's Avatar
Eddie1979
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
*ARP Main Studs
That's the one I was thinking of as well, should be good for at least 500 RWHP using the APS single kit. Agree?
Does the + $1000 core cost mean that if you don't send in your shortblock you pay that much extra?
Old Apr 13, 2005 | 08:36 AM
thawk408's Avatar
thawk408
I was thinking the same, should be good for 500rwhp if not more. The + $1000 core means that they charge you that much more. Then when you send them your shortblock they refund you $1000.
Old Apr 13, 2005 | 09:04 AM
Eddie1979's Avatar
Eddie1979
Sounds like a fairly decent price especially if you can remove/replace the shortblock on your own. Would save big labor costs.
Old Apr 13, 2005 | 09:34 AM
Gman2004's Avatar
Gman2004
They will charge you the extra $1K when you buy the block and when you return yours they will refund the $1K.
Old Apr 13, 2005 | 11:58 AM
002-M-P's Avatar
002-M-P
I have read the Arias pistons can handle up to 25 psi unless you get the zero silicon version....does anybody know this info on those CP Pistons?
