Need help with Vortech FMU
Old Apr 15, 2005 | 10:18 AM
zcar03's Avatar
zcar03
Default Need help with Vortech FMU
I am hooking this vortech FMU that comes with the vortech supercharger to another car. My question is.... What turns the fuel pump on? I gave power to the pump and the pump turned on right away (this is out of the box not hooked up to the car). I thought that the pump would only engage when a boost was present. Do I need something else to control when it turns on and off?
I have the fuel pump and the blue piece that has a vacuum port on top and an IN and OUT fuel fittings. Thanks
Old Apr 15, 2005 | 10:52 AM
S12 driver's Avatar
S12 driver
The SS box controls when the pump is on.
Old Apr 15, 2005 | 11:21 AM
jpc350z's Avatar
jpc350z
The S.S. box receives MAF signal, RPM and manifold pressure and decides when to turn on the fuel pump..
Old Apr 15, 2005 | 11:41 AM
booger's Avatar
booger
The SS box turns on the fuel pump with a boost sensor and rpm signal . The blue thing you have is the FMU .Since you dont have a SS box, your going to have to find some type of switch to to send power to the fuel pump . So it turns on at a set rpm , and or boost setting . Once the pump is running , the FMU will increase the fuel preasure as the boost rises . That is done by running a vacuum hose from your maniflold to the FMU .
Old Apr 15, 2005 | 12:38 PM
zcar03's Avatar
zcar03
OK great. Ill hook the ground up to my hobbs switch so that the fuel pump turns on when the switch closes the circuit at boost > 0 . Thanks
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
