HKS Super Charger Installed "WOW"
Old Jan 25, 2006 | 10:04 AM
  #241
Chebosto's Avatar
Chebosto
Originally Posted by gringott
Cams + install = P
P = Plenty
Your math is fantastic !
Old Jan 25, 2006 | 09:01 PM
  #242
brewster's Avatar
brewster
HKS doesn't recommend changing the stock plenum & alot of us want to keep the OEM appearance with the HKS kit. That being said has anyone added a Skunk Racing Plenum spacer? I'm wondering how it affects the A/F ratios with the HKS SC & would the OEM engine cover still fit? The Skunk spacer alone can increase HP ~9 on a NA engine. Has this simple thing addressed the air flow issue to the front cylinders? I'm still wondering if HKS will put out a SC or a turbo for the G35c.
Old Jan 25, 2006 | 09:22 PM
  #243
itsjoshufocker's Avatar
itsjoshufocker
just curious.. could you put... lets say a HKS ssq blow off valve and a KJR lightweight (not underdrive) pulley on this? this could be something id like to drop into my baby.. but still looking around
Old Jan 25, 2006 | 09:29 PM
  #244
k3silk's Avatar
k3silk
i wonder with the hks ST and TT comign out will we see the HKS supercharger price go down?
Old Jan 26, 2006 | 09:11 AM
  #247
illZ's Avatar
illZ
Have you read through this thread?
Old Jan 26, 2006 | 06:16 PM
  #248
MR RIZK's Avatar
MR RIZK
Are you sure that is was tuned with the navigator? Did it have to be unlocked or the map wiped before starting?
I currently have the HKS SC but keep being told that the navigator cannot tune it.
Originally Posted by NINJA-Z
Picking her up Saturday the 28th from AAM, to go along with the kit I got the 440cc injectors, and the angled plenum spacer, all tuned with the Navigator.
Old Jan 26, 2006 | 06:42 PM
  #250
schweatty's Avatar
schweatty
They had to call HKS and get a password cause the F-Con is password protected.
the navigator also must be unlocked by a HKS Pro-dealer
Old Jan 27, 2006 | 07:16 AM
  #251
PumpedVA's Avatar
PumpedVA
I will have some new dyno #'s in a week or so. AAM is installing some cams now
Old Jan 27, 2006 | 10:43 AM
  #252
illZ's Avatar
illZ
What are you currently putting down? (numbers)
any plots?
Old Jan 27, 2006 | 02:19 PM
  #253
Reaper700's Avatar
Reaper700
with Stillen Exhaust and HKS SC I get 315hp to the wheels
Old Jan 28, 2006 | 04:15 AM
  #254
MR RIZK's Avatar
MR RIZK
What cams and spec have you selected and why? Sticking with the Fcon or you opting for another ecu at the same time?
Old Jan 28, 2006 | 01:42 PM
  #255
illZ's Avatar
illZ
He was running the FCON V PRO.
Old Jan 28, 2006 | 06:22 PM
  #256
PumpedVA's Avatar
PumpedVA
JWT because I need more top end HKS drops of hard after 5k. and yea staying with the V pro
Old Jan 29, 2006 | 05:05 PM
  #258
Z BOY's Avatar
Z BOY
mine doesn't start to drop until 6400.
Old Jan 29, 2006 | 05:09 PM
  #259
HKSPWR's Avatar
HKSPWR
Default Injectors, Spacer, Tune
Z boy man the S/C is so much stronger with the spacer and injectors and the tune, I know its hard to believe but it runs so much stronger.
Old Jan 29, 2006 | 05:13 PM
  #260
Z BOY's Avatar
Z BOY
i plan to move in that direction, but i'm gonna wait until others have done it and worked out the kinks.
