low idle with vortech
Old Apr 25, 2005 | 09:54 PM
freezeg35's Avatar
freezeg35
Default low idle with vortech
Got it on the road tonight, and have noticed that when i get to a stop light, idle is around 600 rpm, shortly there after it drops to 300 and just sits there. If i rev the motor it does the same thing, 600 then 300. Should i see the dealer and have him bump up the idle? Thanks.
Old Apr 26, 2005 | 05:16 AM
booger's Avatar
booger
do you have cams and bigger injectors ? I have the same problem , but my blower is off right now so I dont know if that is some of it
Old Apr 26, 2005 | 06:47 AM
freezeg35's Avatar
freezeg35
no boog, bone stock, no mods other than the vortech. Do you think it might be the parasitic draw that the supercharger makes that may put more drag on the system?
Old Apr 26, 2005 | 07:04 AM
leemik's Avatar
leemik
I'm sure the blower changed your intake characteristics You might need to do the air relearn procedure (search here for it).. either that or you have a vacuum leak..
--mike
Old Apr 26, 2005 | 09:58 AM
mcduck's Avatar
mcduck
check your vacuum lines. sounds very much like a vacuum leak
Old Apr 26, 2005 | 10:19 AM
gspot35's Avatar
gspot35
I second vacuum leak....use an air compressor and blow air into the line. You'll find the leak very quickly.
Old Apr 26, 2005 | 10:20 AM
gspot35's Avatar
gspot35
uh, I mean third it
Old Apr 26, 2005 | 04:30 PM
freezeg35's Avatar
freezeg35
Would a vaccum leak not be present all the time though. What i mean by that is the idle is fine when the car is cold, it sits at 800rpm.
Old Apr 27, 2005 | 04:26 AM
jpc350z's Avatar
jpc350z
When the car is cold started the ECU bumps the idle until car warms up (open loop). My cold idle is higher than 800. A Leak sure sounds like the problem..
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
