E.G.T. or Fuel Pressure
Old Apr 28, 2005 | 11:24 AM
1 2 NV's Avatar
1 2 NV
Default E.G.T. or Fuel Pressure
Well I decided to get three A-pillar gauges just to stay with the theme of the car.(the three stock center gauges) So I am going to get boost and A/f. But what is more important E.G.T. or fuel pressure. I feel both of them are important but cant cancell either one out. So for all the guys out there that are running boost already, which gauge should have priority? I am getting the T-netics kit so I will not be doing any tuning if that helps at all.
Old Apr 28, 2005 | 11:27 AM
MIAPLAYA's Avatar
MIAPLAYA
Well since you have the a/f gauge as long as it is a wideband you can drop the EGT as they would be doing the same thing... Although I must say you'r fuel pressure doesn't move much. I personally have boost, egt and fuel pressure in my Autometer a pillar and water temp and oil temp in my nav.
Old Apr 28, 2005 | 11:29 AM
G3po's Avatar
G3po
Default gauge
I vote Fuel pressure (especially if you are useing a Rising rate regulator or FMU), though I use both Fuel PSI and EGT on mine..
Old Apr 28, 2005 | 11:55 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
i vote egt...but, i admit, i will be getting a fuel pressure gauge
TODD
Old Apr 28, 2005 | 12:44 PM
ZZtopp's Avatar
ZZtopp
Default Which gauges?
If I was limited to either two or three gauges for my APS TT system, which would be the most necessary? The dealer recommended boost, and said oil temp was more important than EGT. Any thoughts?
Thanks in advance....
Old Apr 28, 2005 | 12:52 PM
MIAPLAYA's Avatar
MIAPLAYA
If you already have a wideband then yeah EGT is not as important. However an EGT or wideband gauge is essential to make sure that your car is running well. Especially in Vegas where it goes from hot to cold you want to make sure you don't lean out when the temp changes a lot. Oil temp is also VERY important. Your water temp is going to very greatly as water rapidly heats and cools. But oil temp does not rise and fall as fast so it is actually a better barometer of how hot or cold the motor is then water temp. (The last statement of oil is courtesy of protocav)..
Old Apr 28, 2005 | 01:02 PM
kcobean's Avatar
kcobean
I opted for Boost and EGT based simply on the fact that the Turbonetics system is tame enough in stock trim that it can't out-run the pump (that's what I understand anyway), so fuel pressure monitoring isn't needed. I might get WB A/F down the road just for additional peace of mind, but that's an expensive option.
Old Apr 28, 2005 | 01:03 PM
MIAPLAYA's Avatar
MIAPLAYA
It would take a lot of power to outrun a Walbro 255lph (it is included with the kit). Like 700 RWHP stuff..
Old Apr 28, 2005 | 01:36 PM
taurran's Avatar
taurran
I found out today that I am, in fact, getting a Turbonetics kit. I'm going to be running Boost and an AEM wideband in the autometer 2-guage pillar pod. Unless you decide to go with some sort of stand alone engine management, you shouldn't need any more.
Old Apr 28, 2005 | 01:49 PM
Zivman's Avatar
Zivman
Stock temp gauge reads water temp? Just wanted to confirm this?
I plan on running:
Oil temp
Boost
Fuel pressure
Wideband
MIAPLAYA's Avatar
MIAPLAYA
I plan on running:
Oil temp
Boost
Fuel pressure
Wideband
yes...
apex locator
Jul 23, 2021 02:27 AM
