UR pully kit w/ Vortech S/C possible?
Old May 27, 2005 | 04:10 AM
jpc350z's Avatar
jpc350z
Originally Posted by luanda
I was interested in the kjr pulley but thought the lighter crank pulley would mean it would rev even quicker and thus exasperate belt dust, slippage, stretch, w
Yes? No?
If the replacement is simply lighter than stock but same diameter the S/C would rev at the same rpm as the stock. A little less engine Tq loss would result..less mass to rotate.
Old May 27, 2005 | 04:16 AM
luanda's Avatar
luanda
It would rev at the same RPM yes but it would get to that RPM quicker (less mass inertia) meaning if there was belt splippage before, there would be more now because the rate of RPM increase (and decrease) would be quicker.
Right?
Old May 27, 2005 | 04:24 AM
jpc350z's Avatar
jpc350z
Right?
Less throttle to get to a comparable speed (rpm). However the mass difference is rather small relative to the total inertia of the engine+drive train that probably wouldn't sense it..
Old May 29, 2005 | 10:10 PM
ReavTek's Avatar
ReavTek
Originally Posted by Phatmitzu
I would assume the boost issue only relates to the smaller size crank pulley correct? We can still change out the water pump, alt pullies without having effect on the supercharger?
+1 Can we keep the other two pulleys from the UR set? (Are they even underdriven?) Also, is anyone interested in a UR Crank Pulley for sale?
Old May 29, 2005 | 11:50 PM
JonathanAboona's Avatar
JonathanAboona
I don't see why you can't keep the other 2 UR pulleys and get a KJR. I am not very familiar with the belt issue with SC motors. They are slipping why? Is their a new tension setting needed for the belts ?
Old May 30, 2005 | 12:12 AM
ReavTek's Avatar
ReavTek
John, could you offer OEM belts or point me to a place where I could get them at a good price? Cause right now I have gates (smaller diameter) belts due to running the UR 3 PC Pulley set. I'd like to run the KJR Pulley with the 2 UR (non-crank) pulleys. Or would a SC kit come with replacement belts?
Old May 31, 2005 | 06:44 AM
ktown z's Avatar
ktown z
ReavTec- I have a stock diameter aluminum crank pulley custom made from ASP. I had it made for about 165. I bought it for the procharger (when I had one). If you want I will trade you my stock sized pulley and belts for your unorthodox undersized pulley and belts. My belts only have around 2000 miles on them. Pm me if interested.
Old Jun 1, 2005 | 05:52 PM
kopo's Avatar
kopo
ktown, can I get in on this deal? How was your experience with the lighter pulley and the SC?
Old Jun 1, 2005 | 05:59 PM
JonathanAboona
we have the lightened stock size pulley for 170 shipped at www.kjrperformance.com
seagrasser
Oct 11, 2015 03:27 PM
azrael
Aug 18, 2004 02:08 PM
esemes
Apr 3, 2004 04:39 PM
huducks
Mar 18, 2004 11:27 AM
