Procharger catch can install... tip....
Old May 13, 2005 | 03:16 PM
can350z's Avatar
can350z
Default Procharger catch can install... tip....
Picked up the Performance Nissan Signal Auto catch can...very nice.. Installed on the passenger side of the intercooler.. Fits great.. Did change the ATI PCV routing a little.. Connected both the inlet line,(was attached to air inlet tube), and the PCV line to the inlet of catch can..easier and more effect than ATI's procedure.. Then ran the single line from can outlet to the connection downstream of airfilter.. No drilling into the air filter required for second connection... Will post more feedback in the next few days.. car is running great otherwise...
Attached Thumbnails Procharger catch can install...  tip....-img_0912.jpg   Procharger catch can install...  tip....-img_0914.jpg
Old May 14, 2005 | 10:00 AM
ss350's Avatar
ss350
nice job
Old May 15, 2005 | 07:11 AM
RBALDINELLII's Avatar
RBALDINELLII
Can you tell me where you hooked into. Was it at the T fitting where the pcv valve and the line from the left valve cover come together. Send pictures if possible. Thanks
Old May 15, 2005 | 11:42 AM
can350z's Avatar
can350z
Default PCV routing
I connected the air inlet line...drivers side valve cover line... to the line coming from PCV valve...passenger side valve cover.. with supplied Tee and ran single hose to catch can.. The balance line between valve covers I did not splice into...no reason to.. see pics...
Attached Thumbnails Procharger catch can install...  tip....-img_0920.jpg   Procharger catch can install...  tip....-img_0921.jpg   Procharger catch can install...  tip....-img_0918.jpg
Old May 15, 2005 | 11:55 AM
RBALDINELLII
Thanks for the answer. I notice you have the crawford cast upper plenum. Did you notice much of a difference in performance and did the FMU have to be adjusted afterwards? Did you notice you were losing oil with no real explanation where it was going in regards to the Procharger. Sorry for all the questions. Just trying to make my system as safe as possible.
Old May 15, 2005 | 02:15 PM
can350z's Avatar
can350z
It's actually a Crawford V5 plenum... Note that the Crawford bar fits...
Plenum has been on car for for over a year NA prior.. worth the money..
No FMU.. AAM fuel system.. Needs more ECU tuning.. dyno this week for A/F adjustments at Technosquare.
No oil loss yet.. not many miles on blower... This is why the pcv system I think is critical in terms of relieving blow-by pressure..
Old May 15, 2005 | 05:29 PM
RBALDINELLII
I've noticed about a lose of a quart over the course of 3,000 miles. I'll get the can this week. Thanks for your input.
Old May 17, 2005 | 08:31 PM
POWERSLIDIN's Avatar
POWERSLIDIN
I've thought about adding one also. Thanks for the info!
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
